Sign up Log in
Retrieve Project Schemes and Categories for all Jira projects via the database
veeru
July 7, 2023
Hello Team,
MySQL 8.0 Query Retrieve Project Schemes and Categories for all Jira projects via the database,
I hope someone helping me.
EX:
 projectname   |  projectlead  |                       fieldlayoutscheme                       | issuesecurityscheme |              issuetypescreenscheme               |              issuetypescheme              |     notificationscheme      |                   permissionscheme                   |              priorityscheme              | projectcategory |                             workflowscheme
 ADJAS           | JIRAUSER10000 |                                                               |                     | ADJAS: Scrum Issue Type Screen Scheme            |                                           | Default Notification Scheme | Default software scheme                              |                                          |                 | jdg-schema-for-project-adjamdjamensis
 ADRYSA          | JIRAUSER10000 |                                                               |                     | ADRYSA: Scrum Issue Type Screen Scheme           |                                           | Default Notification Scheme | Default software scheme                              |                                          | Linking_CatTwo  | jdg-schema-for-project-adryasa
Florian Bonniec
July 7, 2023
Hi @veeru
You can use the database schema shared by atlassian to see table relation.
https://developer.atlassian.com/server/jira/platform/database-schema/
Regards
veereshpatil0101 July 8, 2023
@veeru
I have seen but that much of I'm not understand to write the query, can you send the MySQL query.
Florian Bonniec
July 10, 2023
Base on the following KB, this should works
https://confluence.atlassian.com/jirakb/retrieve-project-schemes-and-categories-for-all-jira-projects-via-the-database-1085181544.html
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,cname from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join projectcategory PC on cte.AssocID=PC.ID and cte.AssocScheme='ProjectCategory'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,NS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join notificationscheme NS on cte.AssocID=NS.ID and cte.AssocScheme='NotificationScheme'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,ISS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join issuesecurityscheme ISS on cte.AssocID=ISS.ID and cte.AssocScheme='IssueSecurityScheme'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,ITSS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join issuetypescreenscheme ITSS on cte.AssocID=ITSS.ID and cte.AssocScheme='IssueTypeScreenScheme'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,WFS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join workflowscheme WFS on cte.AssocID=WFS.ID and cte.AssocScheme='WorkflowScheme'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,PRS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join permissionscheme PRS on cte.AssocID=PRS.ID and cte.AssocScheme='PermissionScheme'
union
select prjkey,prj.lead as Prjlead,cte.AssocScheme as Category,FLS.name from project prj join (select p.id as pid, p.pkey as prjkey,sink_node_id as AssocID, sink_node_entity as AssocScheme from project p join nodeassociation na on p.id = na.source_node_id and source_node_entity='Project') as cte on cte.pid=prj.id join fieldlayoutscheme FLS on cte.AssocID=FLS.ID and cte.AssocScheme='FieldLayoutScheme'
union
select prj.pkey as prjkey,prj.lead as Prjlead,'PriorityScheme' as Category, fcs.configname from project prj join configurationcontext cct on cct.project=prj.id and customfield='priority' join fieldconfigscheme fcs on fcs.id=cct.fieldconfigscheme and fieldid='priority'
union
select prj.pkey as prjkey,prj.lead as Prjlead,'IssueType Scheme' as Category, fcs.configname from project prj join configurationcontext cct on cct.project=prj.id and customfield='issuetype' join fieldconfigscheme fcs on fcs.id=cct.fieldconfigscheme and fieldid='issuetype'
order by 1,3
Regards
