Rich Text editor is missing.
Vanish Patel September 14, 2015
Hello.
I recently made changes but now I have lost my rich text editor within Agile Kanban boards.
They used to show up on description and comment fields but now it does not work.
Thanks.
3 votes
Nic Brough -Adaptavist-
September 14, 2015
You probably need to undo the changes that appear to have broken it.
Specifically, check the "renderers" in the field configuration for the project that the issues are in.
Mark Ahnell
Thanks @Nic Brough -Adaptavist-@!  That was the issue for me also, it was my Field Configuration, for "Comment", I had "Default Text Renderer".  Changed it to "Wiki Style Renderer" and I was good to go!
Vanish Patel September 15, 2015
Thanks. I didnt even think I touched those settings.
