We are using jira version 7.6.6 and the above issue is not allowing us to edit the description easily. Is there any issue in your backlog to resolve this conflict issue between 2 of your plugins?
Vaani
It seems that you are facing the issue addressed in the following KB: https://confluence.atlassian.com/jirakb/rich-text-editor-administration-screen-shows-conflict-with-wiki-renderer-macros-plugin-873909993.html. You will find the resolution detailed in the KB, which is to disable the html macro.
