Risk Management
Khai Bulatao
October 4, 2021
We are setting up out Project/ s in JIRA and we'd need to track our risks (with the necessary risk details) that can be pulled as a report. I'd like to ask what's the recommended structure and any samples on how current projects set up their risk management in JIRA.
Thank you!
3 accepted
5 votes
Curt Holley
October 4, 2021
HI @Khai Bulatao
Plug-ins are great and provide nice visualisation/reporting options.
But you can get started by simply creating a Risk issue type and giving it some relevant custom fields (Impact, Likelihood etc). You can also give them a custom workflow based on Risk ROAMing.
This is a free and easy way to get started. Plus you can build dashboard and confluence views to assist present the data.
4 votes
Marion Lepmets _SoftComply_
Hi Khai,
In case you would like to manage risks in Jira and report them in Confluence, you could try out the SoftComply Risk Manager app.
We have just released a Confluence extension to the Risk Manager app on Jira Cloud to make reporting super easy. You can display the Risk Matrices and the Risk Table with all your risks and associated details on your Confluence pages by using this extension.
In case of questions, please let me know.
Kind regards, Marion
Khai Bulatao
October 5, 2021
Thank you for this, I will check this one out. :)
4 votes
Suvradip Paul
October 4, 2021
Hi @Khai Bulatao ,
Thanks for posting and welcome the community. I am not sure you are planning to use any marketplace plugins to achieve this or not. If  yes, you can check these marketplace plugins and see if it solves your purpose.
  1. https://marketplace.atlassian.com/apps/1213146/risk-register?tab=overview&hosting=cloud
Alternatively, you can follow the below mentioned article to handle risk through issue type, custom fields and creating workflows - https://community.atlassian.com/t5/Agile-articles/How-Atlassian-uses-Jira-to-manage-risks-and-compliance/ba-p/896891 and https://community.atlassian.com/t5/Agile-articles/How-Atlassian-uses-Jira-to-manage-risks-and-compliance/ba-p/899058.
Please check and let me know if that helps.
Note :  I am not promoting any marketplace app and the above response and recommended app was just an example based on user query.
Cheers
Suvradip
Anna-BigPicture
Hi @Khai Bulatao
If you consider plugins, BigPicture (PPM tool) can provide the solution you are looking for.
Apart from supporting project management, the plugin includes a risks heat-map, which can be used to visualize the level of risk resulting from, e.g., the risk assessment by considering the category of probability or likelihood against the category of consequences or severity. Axes are fully configurable and can be adjusted to SAFe ROAM Quadrant as well.
