I find the feature of roll-up the estimated time for a issue to the parent issue in a plan very comfortable.
I would also like to see the the rolled-up estimate to the entire sprint. I guess it is not that easy as the sprint is not a type of issue.
Is there any way to see the rolled up estimate for the entire sprint?
This would be very helpful for the "management view" of sprint-planning.
Any ideas or hints?
Hi @Emil Obermayr and welcome to the Community!
If you do the sprint planning from your board backlog, the rolled up estimates are there:
When you use your scrum board as an issue source for your plan, you can also make sprints visible at the top on the timeline. At that point, your capacity and allocated work are visible by sprint, as you can see in this example:
Hope this helps!
Still a question: I tried the Scrum Board, but I could not find the feature to see the sprints at the top at the timeline. How do I achieve this?
I tried the "show capacity on timeline"-setting, but nothing appears on the timeline of my plan
