Rolling Up Status Transitions Across Multi-Level Issue Hierarchy
Sameeksha Shetty August 26, 2024 edited
I'm working with a Jira issue hierarchy that has three or more levels. Here's a simplified version of the hierarchy:
  • Epic
  • Story
  • Sub-task
What I'd like to achieve is this:
  • When a Sub-task is transitioned to "Done," the parent Story should automatically transition to "Done."
  • Furthermore, when all Stories within an Epic are marked as "Done," the Epic itself should also transition to "Done."
I'm currently using Jira Cloud and I’ve set up automation rules, but I'm facing challenges with ensuring that the status transitions correctly roll up to the parent and grandparent levels. Specifically, I want to ensure that the parent issue (Story) and grandparent issue (Epic) are automatically updated when the child issues are completed.
Has anyone successfully implemented this kind of status roll-up across multiple levels? If so, could you share how you configured your automation rules or workflows to achieve this?or Can it be achieved by any other method?
Thanks in advance for your help!
Arun Unnikrishnan
August 26, 2024
@Sameeksha Shetty You may have to use two automations to achieve this.
One for Transitioning Story based on Sub-Task and the other for transitioning Epic based on the Story.
You may use the trigger - When issue transitioned
Check if the transitioned issue is Sub-task using an Issue Type condition
Add a branching for Parent and check if Sub-Task status match Done/Complete using a Related Issue condition.
And finally finally transition the Parent (story) to Done if above condition is true.
Similarly, you can do for Story-Epic status change.
Hope this helps.
Thank You @Arun Unnikrishnan
Is there any other way to achieve this?
I've tried setting up this rule before but it doesn't seem to work for Epic-level issues It only updates the parent Story and shows a success message.
Arun Unnikrishnan
August 26, 2024
@Sameeksha Shetty This can be achieved.
Can you share the screenshots of your automations?
yes!
Arun Unnikrishnan
@Sameeksha Shetty  I think you should spilt the automations into two. one for story transition and other one for EPic transition. it will work.
FREE
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
