×Hi Guys,
Need help in creating an automation flow.
I am trying to send a Web Request for each value available in multi-select list field.
HTTP Request is working and able to get the desired JSON response for each multi-select list field value. But now I want to append each HTTP request result into a read-only text field. Kindly suggest, how can I append data into a single field.
You cannot change the read only field, maybe is better to create a new field and add the new information to this field with the correct information that you want to fill.
When you create the new field "custom" you can define it as multiple choice list
