×Hello, I've implemented SSO via Atlassian Access for Jira and Confluence Cloud applications successfully before. But was trying to implement this time to the Jira Software (with JSM) and Confluence DC applications that have large userbase of 12000+
1) As I read the Atlassian recommendation article, it is talking about the setup using SSO inbuilt app. Have you used this app? What are your experiences?
2) I am still finding details of this SSO App vs the popular marketplace vendor apps like Jira User Sync, which one is best? I don't see much difference between the features.
3) Any best practices tips you can recommend before we initiate the set up in our Sandbox environments?
4) We have two directories that users are coming from into Atlassian Suite. I see SSO app given by Atlassian configures to pull only 1 directory. Is my understanding true?
Happy to provide the responses below, looking to gather as much as I can and change this question to a discussion. :)
Sri
Happy to contribute to the debate! I'm the content manager at resolution, the vendor of the most widely installed SSO solution for Data Center.
Since we were getting a lot of questions like yours, at resolution we created a full feature comparison between the Data Center SSO functionality and what our SAML SSO apps provide. You can check it here:
Feature comparison: resolution SSO vs Data Center SSO
That should clarify what you can expect from both sides. Some additional remarks to guide you:
Below are the links for your reference:
We offer every Atlassian customer free support and meetings during your evaluation to explore your requirements and help you set everything up, even if it means doing work on your IdP to get ready for the installation. Don't hesitate to reach out to my support colleagues when you're ready to get your hands dirty!
If you want to compare some alternatives. (nothing against mO SSO, I have no experience with them)
I used the EasySSO app for my single sign on implementation.
Works well for me. In particular I leverage the kerberos based authentication, which is a better user experience for users logging in from windows desktops then SAML.
(I am a customer, I dont work for them)
Hey Srikanth,
Since you have a large userbase of 12000+, I would recommend you to go with one of the following plugins:
Both these applications are capable of handling a large user base with ease. Along with priority support, they are also updated frequently and come with additional security features like:-
I can also explain the differences between the Inbuilt SSO plugin v/s miniOrange plugin. We can choose the one that best goes with your use case!
We also offer free demo and setup assistance! Feel free to reach out to us at atlassiansupport@xecurify.com.
P.S. - I work for miniOrange, a top vendor on the Atlassian Marketplace.
