Trying to add some custom SIL script fields, however when I try to add one, they don't appear under the advanced option in Custom Fields?
Is there something else I need to enable in JIRA to allow this type of field to appear?
Unfortunately, Jira Cloud API is limited compared to the Jira Server API. Scripted fields are not allowed in Jira Cloud. As a workaround you can create a custom field and then fill it up in post functions.
You are welcome!
