Has anyone seen this weird behavior where there is an error saying "To update this sprint you must have Project Administrator permissions for all of the following projects: project A, project B"?
However, looking at the board's configuration of filter, it should only need admin to project A - it doesn't have any issues in project B.
Error happens in two different cases
1. When a user is trying to start a sprint
2. When a user is trying to close a sprint
Versions:
JIRA 6.2.2
JIRA Agile/Greenhopper: 6.3.12
David,
please could you try to create an Agile board for the existing project A and verify that it works fine?
Fabio
I was able to create a new Agile board for projectA and it's fine.
Ok, maybe it's time to open a ticket to support.
Atlassian support indicates that there were projectB issues in the board at sometime or another
To "close" a question, mark the best answer correct with the tick mark to the left of the answer.
Hello David,
even if there're no issue related to Project B, because your Board is cross project, you need to be project administrator in both project to start/close a sprint.
Please, take a look here https://confluence.atlassian.com/pages/viewpage.action?pageId=298978639
Hope this helps,
Fabio
We just encountered this issue and it seems to be caused by two different projects having the same sprint name. Got to that by using this piece of support from knowledge base:
A Sprint = "ASDF Alpha" and Project != ASDF
We got that the same sprint (by ID) is used between two projects. It looks a person from another project assigned some tickets to our sprint by modifying Sprint field in tickets. We had to revert those changes back.
project = projectA AND issuetype in (Bug, Task, "User Story", Sub-task) AND status in (Open, "In Progress", Reopened, "Resolved - Needs Verification", Closed, "Dev - In Progress", "QA - In Progress") ORDER BY Rank ASC
Disclaimer: I didn't create this filter, some scrum team did :P
I didn't many folks emailing me when we were in JIRA 5.2.2, however after the upgrade there have been a few. One had a simple filter "project = projectA ORDER BY Rank ASC". Both had the common issue where they needed to be admin in projectB. (Both cases projectB is our Ops project)
Versions:
JIRA 6.2.2
Hello David,
please could you share your dashboard filter?
Fabio
i'm pretty sure the Agile board filter does not have any issues from project B. The filter is targeted only to project A. I looked at the filter and it doesn't have any project B issues.
Are you sure that the board do not contain any issue/task/sub-task associated to project B? Is there any issue you moved from project B to project A?
Read the story
