SQL-error during import of data from production
Rune Hellem June 14, 2022
About
During dump of data from prod to test in JIRA failes. JIRA won't start due to errors found in the log such as
2022-06-14 08:31:51,601+0200 JIRA-Bootstrap ERROR      [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
com.atlassian.jira.exception.DataAccessException: org.postgresql.util.PSQLException: ERROR: permission denied for relation moved_issue_key
	at com.atlassian.jira.startup.DatabaseLauncher.cleanupDatabaseTableName(DatabaseLauncher.java:254)
	at com.atlassian.jira.startup.DatabaseLauncher.cleanupDatabaseTableNames(DatabaseLauncher.java:210)
	at com.atlassian.jira.startup.DatabaseLauncher.start(DatabaseLauncher.java:73)
	at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:139)
	at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:307)
	at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:202)
	at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:135)
	at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:102)
	at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
	at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:100)
	at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:154)
	at java.base/java.lang.Thread.run(Unknown Source)
Caused by: org.postgresql.util.PSQLException: ERROR: permission denied for relation moved_issue_key
Versions
Production is currently hosted on Win 2012, but we are about to migrate to Win 2019. Therefore we need the dump/import of data to be working without issues.
JIRA
8.20.2#820002-sha1:829506d
Postgres
PS C:\Windows\system32> psql --version
psql (PostgreSQL) 10.19
Export
On the production server the export is done using command
d:\postgresql\bin\pg_dump.exe  -U postgres -d jiradb --format=c --file=e:\backups\dbs\jiradb_20220614_020008.pgdump
Import
Import script has done the following preparations before import
DROP DATABASE jiradb;
CREATE DATABASE jiradb;
grant all privileges on database jiradb to jira_user;
GRANT ALL PRIVILEGES ON ALL TABLES IN SCHEMA public TO jira_user;
On the test instance the data is being imported using command
d:\postgresql\bin\pg_restore.exe -U postgres -d jiradb --no-privileges --no-owner -v -1 d:\temp\latest-backup.pgdump
Errors being logged
JIRA won't start, 5 errors are being logged, in brief
2022-06-14 08:51:18,645+0200 localhost-startStop-2 ERROR [o.a.c.c.C.[Catalina].[localhost].[/]] Exception sending context destroyed event to listener instance of class [com.atlassian.jira.startup.LauncherContextListener]
... 130 lines omitted ...
... 98 more
Caused by: org.postgresql.util.PSQLException: ERROR: permission denied for relation propertyentry
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2552)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2284)
Show all 143 lines
2022-06-14 08:53:44,979+0200 JIRA-Bootstrap ERROR [c.a.jira.startup.ComponentContainerLauncher] A fatal error occurred during initialisation. JIRA has been locked.
... 151 lines omitted ...
... 117 more
Show all 164 lines
2022-06-14 08:53:45,042+0200 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks] We couldn't start JIRA
2022-06-14 08:53:45,042+0200 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks] An error occurred while trying to start JIRA. We can't give you any more detail right now, we suggest checking the logs for more detail and contacting our support team.
See our documentation for more information on contacting our support team and creating a support zip.
2022-06-14 08:53:45,261+0200 JIRA-Bootstrap ERROR [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
... 11 lines omitted ...
Show all 27 lines
Rune Hellem June 26, 2022
The below command resolved the issue for me, got help from a colleague of mine.
d:\postgresql\bin\pg_restore.exe --username jirs_user -d jiradb -O -W --format=c d:\temp\latest-backup.pgdump
Beats me, but it works
Nic Brough -Adaptavist-
June 15, 2022
It's pretty clear that this is a permissions issue in the database.
Could you try re-running
after the import (and also check that Jira is definitely using jira_user for access - look at Jira-home/dbconfig.xml
Rune Hellem June 20, 2022
It is without doubt my DBA skills that is not up to date
C:\Windows\system32>psql -U postgres -c "grant all privileges on database jiradb to jira_user;"
GRANT
C:\Windows\system32>psql -U postgres -c "GRANT ALL PRIVILEGES ON ALL TABLES IN SCHEMA public TO jira_user;"
GRANT
C:\Windows\system32>psql -U postgres -c "GRANT ALL PRIVILEGES ON ALL SEQUENCES IN SCHEMA public TO jira_user;"
GRANT
C:\Windows\system32>psql -U postgres -c "GRANT ALL PRIVILEGES ON ALL FUNCTIONS IN SCHEMA public TO jira_user;"
GRANT
C:\Windows\system32>psql -U jira_user -d jiradb -c "select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype from public.propertyentry O_S_PROPERTY_ENTRY"
