SSL certificate Connection speed is very slow
蘇子堯(Klus) October 23, 2016
why i try to log in JIRA with https  and  see my user profile. The "user profile" screen will take a long time to appear
Jonas Andersson
October 23, 2016
Very little information.. Did you just switch to SSL? You changed the baseurl? Do you terminate SSL on JIRA itself? If not, i.e doing it on an apache mod proxy, are you referring to the rewrite proxy in your server.xml? You need to provide way more information if you want a solid answer.
