SSO OIDC - Unknown State in Response Error - [Frequently]
Reab May 3, 2021
We are using Jira Software SSO through OIDC and Keycloak. However, we frequently get "We can't log you in right now" after successful login  while actually the user has logged in and able to access the system (false positive) as shown below:
The server logs:
 /plugins/servlet/oidc/callback; user: USERNAME ERROR USERNAME /plugins/servlet/oidc/callback [c.a.p.a.i.web.filter.ErrorHandlingFilter] [UUID:  Unknown state in response
com.atlassian.plugins.authentication.impl.web.usercontext.AuthenticationFailedException: Unknown state in response
at com.atlassian.plugins.authentication.impl.web.oidc.OidcConsumerServlet.lambda$doGet$0(OidcConsumerServlet.java:111)
at java.util.Optional.orElseThrow(Optional.java:290)
at com.atlassian.plugins.authentication.impl.web.oidc.OidcConsumerServlet.doGet(OidcConsumerServlet.java:111)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:626)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:37)
at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:47)
... 48 filtered
I need to investigate this issue where to look?
Elias Brattli Sørensen - Kantega SSO
Hi guys,
I have been working quite a lot with OIDC, and have some thoughts and hypotheses.
To troubleshoot this, I would hit the F12 button and perform a network capture to see the requests in the browser. From the looks of it, the callback URL was hit again somehow, after the successful login was performed. In that case, the state variable is no longer cached as the server likely received a replay of a completed login. The explanation for such an error could be many, but maybe something in your network stack leads to this replay / hiccup?
Another possibility that might explain such issues sometimes is that this is caused by a faulty sticky session configuration in a multi-node setup or something, or that the shared cache / file system between nodes is out of sync.
Were you able to resolve the issues, both of you? @Joe Red  @Reab
Elias
Kantega SSO
Joe Red
Anyone have any thoughts on this?
I am receiving the same error with a very similar setup as @Reab
@Reab What did you do to troubleshoot?
Gita Meskauskas February 16, 2024
I am having similar issue, any suggestions? @Joe Red @Reab
Hi @Gita Meskauskas ,
Can you share more about the errors you're experiencing? While I am not familiar with  Atlassian's OIDC plugin, I am familiar with OpenID Connect and Atlassian software, and I'm happy to help you understand the issue.
See my other comment for suggestions and thoughts.
Best,
Elias
Kantega SSO
Like Gita Meskauskas likes this
Register now
