SUM Story Points subtasks, tasks and epics
Carmen Blázquez Jiménez April 10, 2024
I want to create a filter using JQL (Jira Query Language) functionality to automatically sum the Story Points of subtasks into tasks and then sum the tasks into Epics. Or some automation.
Sebastian Krzewiński
April 10, 2024
Hi @Carmen Blázquez Jiménez
Please check this rule from automations playground - https://www.atlassian.com/software/jira/automation-template-library/rules#/rule/9919294
Seba
Hello Seba,
Thank you so much! I am following with the steps the link but when I selected the last box and there is an error:
What should I put in the last box, SP?
April 10, 2024
Adding to Sebastian's answer...
Rather than using the template from the automation library, please use the template directly from your project:
  • navigate to the rules list for your project
  • select templates
  • select the rule highlighted in this image
The benefit of using the template from your project is it will correctly detect which story points field to use for a company-managed versus team-managed project.
Carmen Blázquez Jiménez April 11, 2024
Thank you so much!!!
Like Bill Sheboy likes this
Hannes Obweger - JXL for Jira
Hi @Carmen Blázquez Jiménez,
I trust that you'll be able to do this in Jira Automation! Just as food for thought: As an alternative, you could also consider Advanced Roadmaps, which should be included in your Premium plan, which will show your issues in their hierarchy and calculate live sum-ups of selected field values, including story points.
If Advanced Roadmaps isn't the right tool, there's also a number of apps available in the Atlassian Marketplace that can help with this. As an example, this would be easy to do using the app that my team and I are working on, JXL for Jira:
For context, JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting
With these, you can build a view like e.g. the one above in just a couple of clicks.
Best,
Hannes
