SVN plug in for Jira Software DC
Emilia Bilenberg
February 27, 2025
I am looking for a good plug in or other ways to integrate a Jira DC instance with SVN (subversion). Current information is very limited, only finding old posts.
All help is appreciated!
Aron Gombas _Midori_
@Emilia Bilenberg Subversion has lots its significance in the world of VCS over the years, but there are still supported apps that integrate SVN to Jira Data Center.
Depending on what you mean by integration, you should check these:
  1. https://marketplace.atlassian.com/apps/1211642/subversion-alm?hosting=datacenter&tab=overview (browse the repo, history and commits related to issues)
  2. https://marketplace.atlassian.com/apps/1213415/better-commit-policy-for-jira-git-subversion-and-more?hosting=datacenter&tab=overview (enforce that Subversion commits, tags, branches follow your team's conventions)
  3. https://marketplace.atlassian.com/apps/1212265/svn-gateway-subversion-links-in-jira?hosting=cloud&tab=overview (similar to the first, but a bit more light-weight and fewer features)
(Discl. item 2 is a paid and supported app developed by our team. Free for 10 users!)
Emilia Bilenberg
March 3, 2025
Thank you!
It is for a customer so I will discuss and present these options to see if anything sounds like something they are looking for.
However, the 3rd option you shared: From what I can see, it is only available for Jira Cloud. Correct?
@Emilia Bilenberg Oh, yes, that is Cloud-only.
