I'm getting the following error in the log
[c.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'java.lang.NullPointerException - null'.
I'm not running Jira 7.2
How do I find out more?
Which plugin ? what was it trying to do ? stack trace?
Dear @Daniel Garcia
I have the same issue in log, but on my side (may be link ??), the assets post function are totally not available, et can no longer edit the ones already in transition.
did you have the same behaviours ?
regards,
Xavier
I wasn't running any assets plugin. I eventually figured out which plugin it was by disabling one at a time can't can't remember much more.
