Scheduled automation error
carlos sarrate February 2, 2024
Hi, I have an automation that runs on newly created tickets in a certain group that fills in a date 30 business days out in a new custom field. Using:  {{issue.created.plusBusinessDays(30)}}
Now I'm trying to fill in this field to all my existing tickets. So I duplicated the automation but I set the trigger to scheduled. This one unfortunately gives me this error.
 Error: The rule has been configured with components that require issues to be provided by the trigger. You need to use the option to run JQL to provide issues. The following components require issues: Issue condition, Edit issue
Can anyone see what I'm doing wrong?
Marc - Devoteam
February 2, 2024
Hi @carlos sarrate
In the automation scheduled trigger the option: Run a JQL search and execute actions for each issue in the query. needs to be checked and a search provided
Trudy Claspill
Or...
After the Scheduled Trigger you need a step such as Lookup Issues that will get a list of issues against which the remaining actions can be executed (with a For Each branch).
carlos sarrate February 2, 2024 edited
@Trudy Claspill and @Marc - Devoteam Looks like both methods require a JQL search is there a smart value that will give me all the open tickets?
Trudy Claspill
You need to construct a JQL filter to retrieve you existing tickets. If the field is new and empty in the issues where you want to fill it then I would recommend a filter that includes this
<Your custom field> IS EMPTY
You probably will want to include other criteria, such as specifying the project(s) that contain the issues.
There are limits on both the number of issues that can be received in a Scheduled trigger JQL and in a Lookup Issues action, so factor that into you JQL.
https://support.atlassian.com/cloud-automation/docs/automation-service-limits/
Like • 2 people like this
