I have experienced this error below, how do I go about this? and how to prevent it from coming back?
I tried clicking the “Fix” button but the Schedule Issue Wizard just keeps on loading and will say “The Scheduler: Error caught while trying to fetch scheduled issue data.” after a while.
Hi @Vera Cruz, Sibyl ,
From what I see from that message is: Jira has an issue with the Parent of the User Story that you are trying to create. From the image I do not realize what that parent is (might be an Epic). Either something happened to that Parent (got deleted, moved or something), OR some parts of the JQL which is used to find that Parent to add the user story to, cannot find it. This is why you receive that second message as well that says that "error caught while trying to fetch scheduled issue data". That means that it cannot find the data which the scheduler is looking for :)
Maybe if you could add a Screenshot with the setup itself, it would give us more information and we could give you better options to fix it :)
Hi, thanks for your input! Apparently someone did accidentally clicked delete and tried to cancel immediately.
@Vera Cruz, Sibyl This appears to ba an issue and as you have an standard account, if i were you, i will check at support.atlassian.com.
HTH
Nicolas
