I have an Epic Screen and associated Field configuration used across multiple company-managed projects. When I edit a project, using this configuration, I can set which fields are hide when empty. Is there a place where I can set the 'hide when empty' fields across all the impacted projects? (there are over 100 projects so I don't want to do them project by project).
Finally found it in Issue layout, Edit settings there is an option to copy to configuration to multiple projects
Hi Ann,
When you go into the issue layout configuration, you should be able to make your changes and save them. Then click the Copy Issue Layout button and select the projects you want to copy it to. This will only work with Jira Software projects and not JSM.
