Screen tabs are combined when moving through transition
Daniel Drysdale _UK_ May 29, 2019
I have 5 tabs on my view/edit screen. When i go to edit the issue, everything works as expected and the correct fields appear on each tab. However if i was to select move to next stage of the workflow. the first 3 tabs have their correct fields and the fields from the final two tabs added to the bottom. Then when you select one of the final two. They replicate the previous tab you were on.
Any ideas on how to fix as this doesnt make sense to me. Ive redone the workflow and removed and added all the fields
Andrew
May 29, 2019
Hi ,
Maybe in transition using different screen?
https://confluence.atlassian.com/adminjiraserver/defining-a-screen-938847288.html
B.R.
Hi, that was my first guess. But the correct screen is selected on all issues. Thanks though can you think of anything else?
Andrew
May 29, 2019
Installed some third part plugins?
Once I had bug in workflow and copy workflow not helped. Then I created workflow from scratch and it resolved problem.
Try recreate schemes for project, maybe it help.
B.R.
Okay, I have quite a few 3rd party plugins. I will try to replicate now :)
Unfortunately that didn't solve either. the fields that are affected display like this on the edit issue screen when not transitioning. It's these fields that are appearing underneath each other tab.
Read the story
