Hello Community,
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue;
import static java.lang.Math.*
import java.sql.Timestamp
def today = new java.sql.Timestamp(new Date().getTime())
def issue = issue as MutableIssue
def cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(""In Analysis Time"")
def cfFuncDate = issue.getCustomFieldValue(cf)
issue.setCustomFieldValue(cf,today)
log.error""==========""+cfFuncDate"
"import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.UpdateIssueRequest
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
DefaultIssueChangeHolder changeholder = new DefaultIssueChangeHolder();
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(""Back to In DEV Count"")
def value = issue.getCustomFieldValue(cf)
def currValue=(Double)cf.getValue(issue)
log.error""-------currval=""+currValue
def newValue;
if (currValue== null)
newValue= 1.0D;
else{
newValue=currValue+1.0D
cf.updateValue(null, issue, new ModifiedValue(currValue,newValue),changeholder);
log.error""---------count=""+newValue"
We have been using the above scripts in our Server Instance in Jira but due to the groovy script not working in the cloud Instance we need to write a fresh scripts with different methods and syntaxs(beacuse the cloud uses API calls) can anyone help me with the scripts for cloud
Thanks & Regards,
Ganesh
The previous code you used on the Jira Server Instance does not apply to the Cloud because you must make REST requests to update the field value.
I am going to assume you are doing the update via Post-Funtion.
You will need to use ScriptRunner's Run Script Post-Function for this. Below are the steps to configure the Post-Function.
1. Go to the transition you want to include the Post-Function and click on the Add post function link as shown in the screenshot below:-
2. Select the ScriptRunner Post-Function option as shown in the screenshot below:-
3. Next, Select the Run Script Post-Function link as shown in the screenshot below:-
Please refer to this ScriptRunner for Jira Cloud code snippet.
Below is the working code snippet with sample values for your reference:-
def issueKey = issue.key
def numberFieldId = 'customfield_10049' //Number Field Id
def autoIncrement = 10 //Specify the amount to increment
if (issue.fields[numberFieldId]) {
def currentValue = issue.fields[numberFieldId] as Long
def updatedValue = (currentValue + autoIncrement) as Long
put("/rest/api/2/issue/${issueKey}").header('Content-Type', 'application/json').body([
fields: [
//Number Field Id
customfield_10049: updatedValue
]).asString()
} else {
fields: [
//Number Field Id
customfield_10049: autoIncrement
]).asString()
Please note that the sample working code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
You will need to include the code in the Additional Condition section of the Post-Function, as shown in the screenshot below:-
Below are a couple of test screenshots for your reference:-
1. For the first test, I am using an issue with a value to the Sampleinumber Field. In this example, the value of the Sample Number Field has been set to 120 and is currently in the To Do status, as shown in the screenshot below.
2. Next, I transition the issue to In Progress status. As expected, the value of the Sample Number field has been incremented by 10 and updated to 130, as shown in the screenshot below:-
3. Next, I will run a test for an issue where no value has been set to the Sample Number field. At the moment, the issue is in To Do status as shown in the screenshot below:-
4. Once I transition the issue to In Progress status, as expected, the value for the Sample Number has been incremented by 10 and updated as shown in the screenshot below:-
Please note that you may need to refresh your page a couple of times to see the effect, as there might be a delay in the Cloud instance displaying the update.
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
