We are using Specific Business logic as a script field, and we are returning the script field logic value in HTML. Since, This HTML type has been used. We are unable to use that field in Gadget list (Pie chart and two dimensional, etc.)
We want this field to work as select list field either on code alteration or in selecting other field types in script field creation, how can we adapt this?
Please assist with your support!
Hi @PRAMOD KUMAR REDDY KASIREDDY
From your description, I will assume you are using a Custom Scripted Field, and the field type you have used is the HTML field. Please confirm.
The HTML Field has been deprecated and is not recommended for use. Instead, please change the field type to a text field.
It would be beneficial to share the Scripted Field code you are using and a screenshot of your Scripted Field configuration. I request this to review it, test it in my environment and provide a better solution.
Thank you and Kind regards,
Ram
