Script Runner - How to add a field on screen
Radhika Shinde February 1, 2023
How can I add a field on a project's field configuration and on the screens.
Tuncay Senturk _Snapbytes_
Hi @Radhika Shinde
I can't say I 100% understood your post but I think you can start with the below code.
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.fields.screen.FieldScreen
import com.atlassian.jira.issue.fields.screen.FieldScreenTab
import com.atlassian.jira.issue.fields.screen.FieldScreenScheme
import com.atlassian.jira.issue.fields.screen.FieldScreenSchemeManager
import com.atlassian.jira.util.ErrorCollection
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField customField = // your custom field to add to the screen
FieldScreenSchemeManager fieldScreenSchemeManager = ComponentAccessor.getComponent(FieldScreenSchemeManager.class)
FieldScreen fieldScreen = fieldScreenSchemeManager.getFieldScreen(FieldScreen.DEFAULT_SCREEN_ID)
// Get field screen tab (assuming you have only one tab or add to the default tab)
FieldScreenTab fieldScreenTab = fieldScreen.getTab(0)
// Add custom field to field screen tab
fieldScreenTab.addFieldScreenLayoutItem(customField.getId())
// Update field screen
fieldScreenSchemeManager.updateFieldScreen(fieldScreen)
List<FieldScreenScheme> fieldScreenSchemes = fieldScreenSchemeManager.getFieldScreenSchemes()
// add custom field to each scheme
for (FieldScreenScheme scheme : fieldScreenSchemes) {
scheme.addFieldScreen(fieldScreen)
ErrorCollection errorCollection = fieldScreenSchemeManager.updateFieldScreenScheme(scheme)
if (errorCollection.hasAnyErrors()) {
log.error(
"Error adding custom field to field screen scheme: " + errorCollection.getErrorMessages())
Bhakti Prasad Panda September 29, 2023
Hello @Tuncay Senturk _Snapbytes_ ,
Check your code once. I don't think this is a right code.
Hi @Bhakti Prasad Panda
Thanks for your message, why do you think it is not the right code?
Bhakti Prasad Panda September 29, 2023 edited
Please put the code in script console of scriptrunner. It will show you the errors.
We are using Jira 9.4.7 and i hope you're using the same so if you can refer below Java APIs, you won't find the methods (you've used in your code) in the article:
https://docs.atlassian.com/software/jira/docs/api/9.4.7/com/atlassian/jira/issue/fields/screen/FieldScreenSchemeManager.html
The methods are available in FieldScreenManager i suppose:
https://docs.atlassian.com/software/jira/docs/api/9.4.7/com/atlassian/jira/issue/fields/screen/FieldScreenManager.html
I would be glad too if i am wrong in here :) but just got this observation.
Yes, you are right, this is quite old version I suppose. They (FieldScreenSchemeManager) need to be changed (to FieldScreenManager)
SERVER
VERSION
8.20.11
