Script Runner and SQL
Eitan Yomtovian January 8, 2023
I try to write a script runner (in post function), that assigns automatically in the sub-task by the value in the component (in the "source issue).
The value of the assignee (in the sub-task) needs to return from a SQL query.
import com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent
import com.atlassian.jira.event.issue.link.IssueLinkDeletedEvent
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.issue.changehistory.ChangeHistory
import com.atlassian.jira.issue.history.ChangeItemBean
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import groovyx.net.http.HTTPBuilder
import groovy.json.JsonSlurper
import groovy.transform.Field
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def fieldManager = ComponentAccessor.getFieldManager()
def componentfieldBug =sourceIssue.components.toString()
//def componentfieldBug = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Component/s'}
def sqlStatement =  """
                    SELECT VALUE
                    FROM [JDCPreProd].[dbo].[AO_E8E966_PROP_VALUE] as prop_value,[JDCPreProd].[dbo].[component] as component
                    WHERE prop_value.REF_ITEM_ID  = component.ID AND component.ID = ${componentfieldBug[1]}
Connection conn = ConnectionFactory.getConnection(helperName)
    Sql sql = new Sql(conn)
    try {
        sql.eachRow((GString)sqlStmt) { row->
        ApplicationUser user = ComponentAccessor.getUserManager().getUserByName(row.VALUE)
        issue.setAssignee(user)
    finally {
        sql.close()
        conn.close()
Someone can overview on the code and tell me what I did wrong?
Please advise,
Eitan.
Ismael Jimoh
January 8, 2023
Hi Eitan
May I ask why you are checking the source issues assigned components via the database rather than the Java api?
Also looking at your query, may I ask why you are parsing issue.setAssignee within your database connection?
I will expect that you store the data from the result of your query in an array or hash set and then iterate over this in a subsequent method that you use for setting your assignee. (In other words, issue.setassignee() should come after your connection close for the database.)
Regards.
Nic Brough -Adaptavist-
January 9, 2023
My very grumpy answer to this is:
Used SQL.
It's not a friendly answer, for which I apologise, but it is accurate.  Why are you using SQL when the API can serve you faster and better?  And the component/s field is not even kept in AO tables?
Like Ismael Jimoh likes this
