Script Runner for Cloud: Team (Next-Gen) vs. Company Managed Projects
William Asbill June 21, 2022
When using the following filter* in Script Runner for JIRA Cloud (Company Managed Project), I get the message "Not available with next-gen projects yet!"
* issueFunction in issuesInEpics("key = AB-12345")
But, my understanding is that Next-Gen projects applies to Team Managed Projects, not Company Managed Projects, as I am using.
Do I need to update, adjust a configuration perhaps?
Nic Brough -Adaptavist-
June 21, 2022
I think we've missed an update there, Next-gen should have been changed to team-managed ages ago.
There's nothing for you to adjust, but do check that project AB is definitely a  Company Managed Project and also that you've not got any Team-managed Epics it might be looking for.
Nic, when I look at the bottom left corner, when in the JIRA project, I do see "You're in a company-managed project". Are you saying that, though I am in a Company Managed Project, I may still have Team-managed Epics?
Kendall Totten
I also have this problem and I see "You're in a company-managed project" too.
Marcio Sete
February 9, 2023
Same problem here. Have you guys cracked it ?
February 12, 2023
Is your AB-12345 an Epic in a team-managed project?
Ofer Cohen April 1, 2023
I have the same problem. My project is company managed, and I get the same error. We do not use next-gen projects.
Any idea why it is happening?
