Script Runner "single issue picker" database schema
Andrew Warburton
March 13, 2020
I have added a custom field of type "Single Issue Picker" and would like to query the value for this in SQL.   Which table stores the issue selected for this custom field?
Christos Moysiadis
March 13, 2020
Hello @Andrew Warburton
Here i have something for you to try:
select *
from customfield cf , customfieldvalue cfv, jiraissue iss
where cf.cfname='SinIssPick' and cfv.customfield = cf.id and iss.id = cfv.issue
Regards
Contemi-EUR: Andrew Warburton
March 25, 2020
Hi @Christos Moysiadis
Thanks, that helps but I need to add a where clause to restrict the results by the "Single Issue Picker" field value.   There is a "stringvalue" column on customfieldvalue but it has a number.  Do you know where I get the value for the single issue picker?
Pierre Ibrahim
August 18, 2023 edited
@Contemi-EUR: Andrew Warburton based on this answer https://community.atlassian.com/t5/Jira-Service-Management/Jira-Database-Table-for-Scriptrunner-Custom-Field/qaq-p/1462817 it doesn't seem possible to return the value of scripted fields.
Usually you'd join customfieldoption on customfieldvalue.stringvalue = customfieldoption.id to get the actual value in cases where customFieldValue has a number in the stringvalue.
However for scriptrunner fields, customfieldoption seems to be blank. I'm still researching this and will update if I find a way to get that result.
Edit: The number value is the issue ID.
select concat(p2.pkey, '-', ji2.issuenum), concat(p.pkey, '-', ji.issuenum) from jiraissue ji
inner join project p
on p.id = ji.project
inner join customfieldvalue cv
on cv.ISSUE = ji.id
and cv.CUSTOMFIELD = 'YourCustomFieldIdHere'
inner join jiraissue ji2
on ji2.id = cv.STRINGVALUE
inner join project p2
on p2.id = ji2.project
The above MySQL query (you'll need to modify if you're on a different database engine) will give you in the first column the issue key from the single issue picker, and the second column is the main issue key
Like • Nitin likes this
Learn more
