Script function failed on Automation for Jira rule: error: groovy.lang.MissingPropertyException: No
Mouna Hammoudi
September 19, 2023
I am using an automation for Jira rule to be executed once the user clicks on a button. I would like to automatically create some linked issues once the user clicks on the button but I receive the following error message:
enter image description here Script function failed on Automation for Jira rule: Script function failed on Automation for Jira rule: UpdateExecutionSummary , file: SuperFeature/rest_superFeatureGenerator.groovy, error: groovy.lang.MissingPropertyException: No such property: issueLinkType for class: SuperFeature.rest_superFeatureGenerator
How can I fix this?
package SuperFeature
import com.atlassian.jira.bc.project.component.ProjectComponent
import org.apache.log4j.Logger
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.util.ImportUtils
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.index.IssueIndexManager
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.event.issue.IssueEventManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent
import com.atlassian.jira.event.issue.link.IssueLinkDeletedEvent
import org.apache.log4j.Level
def log = Logger.getLogger('atlassian-jira.log')
log.warn("MOUNA: ")
log.warn("MOUNA COMPONENT NUMBERS : "+ issue.getComponents().size())
List<String> componentList = new ArrayList<String>()
def authenticationContext = ComponentAccessor.jiraAuthenticationContext
if (issue.getComponents().size()==0){
    log.warn("MOUNA CAMELIA COMPONENTS")
    issue.update {
    String text= "Issue does not have any components\n"
    setCustomFieldValue('Execution Summary', text)
}else if(issue.getFixVersions().size()==0){
            log.warn("MOUNA CAMELIA VERSIONS")
            issue.update {
                String text= "Issue does not have any fix versions\n"
else{
            log.warn("MOUNA CAMELIA ELSE")
        int componentSize=issue.getComponents().size()
        for(ProjectComponent component : issue.getComponents()) {
                componentList.add(component.getName())
        issue.update {
            String text= "The super feature "+issue+" will be split into "+componentSize+
            " features, one for each component:\n"
            for(String component: componentList){
                text = text +"-"+ component+"\n";
// Issue issue
def issueManager = ComponentAccessor.issueManager
def issueFactory = ComponentAccessor.issueFactory
def subTaskManager = ComponentAccessor.subTaskManager
def issueLinkManager = ComponentAccessor.issueLinkManager
def userManager = ComponentAccessor.userManager
MutableIssue newIssue= ComponentAccessor.issueFactory.issue
newIssue.setProjectObject(issue.getProjectObject())
newIssue.setSummary("MOUNA CAMELIA")
newIssue.issueTypeId= 19
newIssue.setAssignee(userManager.getUserByName("mouh"))
newIssue.setDescription(issue.getDescription())
                    log.warn("MOUNA CAMELIA component"+ component +" NEW ISSUE "+ newIssue)
                     log.warn("MOUNA CAMELIA Component "+ component+" issue.getId() "+ issue.getId()+" issueLinkType "+issueLinkType+" sequence "+ sequence)
                    issueLinkManager.createIssueLink(issue.getId(), newIssue.getId(), issueLinkType, sequence, authenticationContext.getLoggedInUser())
