I am trying to use the HAPI API for Scriptrunner and I am getting the following error:
My code is very simple, I am using the following:
Collection < ProjectComponent > updatedComponentList = issue.getComponents()
updatedComponentList.removeAll(component)
issue.set {
setComponents(updatedComponentList)
I have found the syntax under this link: https://docs.adaptavist.com/sr4js/latest/hapi/update-issues
Here is my whole code if needed:
package SuperFeature
import org.apache.log4j.Logger
import com.atlassian.jira.project.version.Version
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.atlassian.jira.bc.project.component.ProjectComponentManager
import com.atlassian.jira.security.JiraAuthenticationContext
import com.atlassian.jira.issue.label.LabelManager
import SuperFeature.Configuration_SuperFeature
import com.adaptavist.hapi.jira.issues.delegate.AbstractIssuesDelegate
def log = Logger.getLogger('atlassian-jira.log')
List < ProjectComponent > finalComponentList = new ArrayList < ProjectComponent > ()
int componentSize = issue.getComponents().size()
int generatedIssuesCounter= 0
for (ProjectComponent component: issue.getComponents()) {
String componentName = component.getName()
def shortenedComponentName = componentName.substring(componentName.indexOf("-") + 1)
def projectName = componentName.substring(0, componentName.indexOf("-"))
if(Configuration_SuperFeature.projectNames.contains(projectName)){
def newIssueproject = ComponentAccessor.projectManager.getProjectObjByKey(projectName)
List < ProjectComponent > newList = new ArrayList < > (newIssueproject.getComponents());
def found = newList.any {
it.getName().equals(shortenedComponentName)
if (found) {
finalComponentList.add(component)
generatedIssuesCounter++
createFeature(issue, finalComponentList)
void createFeature(Issue issue, Collection < ProjectComponent > componentList) {
JiraAuthenticationContext authenticationContext = ComponentAccessor.getJiraAuthenticationContext();
long issueLinkType = Configuration_SuperFeature.hierarchyIssueLinkType as long
long sequence = Configuration_SuperFeature.sequence as long
long myissueID = issue.getId() as long
// the key of the project under which the version will get created
final String projectKey = Configuration_SuperFeature.projectKey
// the start date - optional
final Date startDate = null
// the release date - optional
final Date releaseDate = null
// a description for the new version - optional
final String description = null
// id of the version to schedule after the given version object - optional
final Long scheduleAfterVersion = null
// true if this is a released version
final boolean released = false
def project = ComponentAccessor.projectManager.getProjectObjByKey(projectKey)
assert project: "Could not find project with key $projectKey"
ProjectComponentManager projectComponentManager = ComponentAccessor.getProjectComponentManager()
for (ProjectComponent component: componentList) {
List < String > newIssueProjectVersionIDs = new ArrayList < String > ()
newIssueProjectVersionIDs = newIssueproject.getVersions().collect {
it.getName()
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(Configuration_SuperFeature.investmentAreaCustomField);
def value = issue.getCustomFieldValue(customField);
def matchedVersions = issue.getFixVersions().intersect(newIssueproject.getVersions(), Version.NAME_COMPARATOR)
ProjectComponent newComponent = projectComponentManager.findByComponentName(newIssueproject.getId(), shortenedComponentName)
def componentArray = new String[1]
componentArray[0]=newComponent.getName()
def versionCreator = ComponentAccessor.versionManager.&createVersion.rcurry(startDate, releaseDate, description, newIssueproject.id, scheduleAfterVersion, released)
def mynewVersions = issue.fixVersions.intersect(newIssueproject.versions, Version.NAME_COMPARATOR).collect {
versionCreator it.name + '-Inbox'
// long newIssueCreatedID = newissue.getId() as long
// def labelManager = ComponentAccessor.getComponent(LabelManager)
// labelManager.addLabel(authenticationContext.getLoggedInUser(), newIssueCreatedID, "SF-Child", false)
// updatedComponentList.removeAll(component)
// projectComponentManager.updateIssueProjectComponents(issue, updatedComponentList)
// issue.setComponents(updatedComponentList)
// issue.update {
// setComponents(updatedComponentList)
issue.set {
Issue newissue = Issues.create(projectName, 'Feature') {
setSummary("["+shortenedComponentName+"] "+issue.getSummary())
setDescription("This feature has been generated as child of a super feature. Please use this text area to add child feature specific information.")
setReporter(authenticationContext.getLoggedInUser())
setCustomFieldValue(customField.getFieldName(), value)
setFixVersions(mynewVersions as String[])
setComponents (componentArray as String[])
setLabels(["SF-Child"] as String [])
newissue.link(Configuration_SuperFeature.hierarchyIssueLinkType, issue)
Can you provide the error message, the link seems to be broken
Register now
