Script import configuration-csv file ?
Boris Demain April 5, 2019
Hi community !
I have to import many projet to Jira with CSV.
Among issues I got Old users as reporter. I don't want create this users in my Jira instance.
How can I import only active User ?
I thought to use CSV configuration file to like that :
"Créé par" : {
"jira.field" : "reporter",
"userChanged" : "false",
"manualMapping" : "true"
"config.value.mappings" : {
"Créé par" : {
if "User active 1" : "New Login User 1",
"User active 2" : "New Login User 2",
else "*" : "Migration"
I got the liste of users. But I don't have any result with that solution, cause ok "*"
Maybe their is a better one.
John Funk
Hi Boris,
Why not create an admin user or "old projects user" or something to that effect. And then import them under that user?
Boris Demain April 7, 2019
Hi, thank you John !
Two reasons... first I didn't thought about that ^^
Second I would be more efficient with less chance of mistake (I need to do manual entry).
If their is no other solution, I will do it.
Thanks again.
Get Certified! ✍️
