Script to add info rich text editor fields and comment
Alex Trebek
February 14, 2023 edited
Hello!
I'm trying to use javascript to append text in rich text editor fields.
It works as expected in Description field with
AJS.$("#description").val(AJS.$("#description").val() + " new *formatted* text");
But the same trick doesn't work in Comment field.
Nothing happens if you call:
AJS.$("#comment").val(AJS.$("#comment").val() + " new *formatted* text")
Although, if you run AJS.$("#comment").val(), then console returns expected value. But it does not appear on screen and it's not being added as a comment if submitted.
By fiddling around in console, I found that this way it almost works:
AJS.$("textarea#comment.textarea.long-field.wiki-textfield.mentionable.wiki-editor-initialised").val(AJS.$("textarea#comment.textarea.long-field.wiki-textfield.mentionable.wiki-editor-initialised").val() + " new *formatted* text");
Added text appears in Comment field.
But if you change anything manually in comment field and run command once again, all manually applied changes are being deleted and the script just adds scripted text to "previous" state of the field.
Has anybody encountered this problem?
Is there any other way to adjust text in Comment field on browser side?
Alex Trebek
Figured it out.
Even more specific reference works:
AJS.$("textarea#comment.textarea.long-field.wiki-textfield.mentionable.wiki-editor-initialised.wiki-edit-wrapped.richeditor-cover").val(AJS.$("textarea#comment.textarea.long-field.wiki-textfield.mentionable.wiki-editor-initialised.wiki-edit-wrapped.richeditor-cover").val() + " new *formatted* text");
