ScriptRunner Enhanced Search - Get issues with linkes issues matching a specific condition
Hans Hugo February 27, 2024
we migrated from Jira Server to Jira Cloud.
A filter query we used with Jira Server was something like this:
project = ABC and issue IN linkedIssuesOf("project = DEF and resolution = Unresolved")
It returned all issues from project ABC which have a linked issue to project DEF which has a resolved resolution.
With Jira Cloud we have to use the Enhanced Search feature which provides a JQL Function "linkedIssuesOf": https://docs.adaptavist.com/sr4jc/latest/features/scriptrunner-enhanced-search/jql-functions#linkedissuesof
But this function does not match our needs because it will return the linked issues itself matching the condition.
Is there a way to write a query similar to the Jira Server version (which returns issues from project ABC instead of DEF) with Jira Cloud / Enhanced Search? Thanks!
Kate Kabir
February 27, 2024 edited
Hi @Hans Hugo
Potentially, you can try the below JQL search example as a guide:
issueFunction in linkedIssuesOf("Project = T2 AND resolution = Done") AND Project = STRAW
The example above will show all the issues from Project = STRAW containing linked issues related to Project = T2.
Can you try this and see how it goes?
I hope this helps. :)
Kind Regards
Kate
Thx, it works. But complex queries will always run in the 30 sec timeout :(
Jasmin Bateman February 27, 2024
Hi @Hans Hugo
Please raise a support ticket with our support team here: SR4JC support so we can get some more information regarding your JQL query and hopefully help you to resolve the 30 second timeout issue.
Jasmin
