×Hey there,
Got some escalation services on an instance ~about 10.
They are all like this below to automatic transition issues in another project which are linked with this in a special sort of link.
If I "Run now" this services they work fine - but they total ignore the interval and do nothing themself.
any ideas ?
JIRA 6.3.7. and Script Runner 3.0.6
Description: | Resolved -> Closed |
Interval: | 5 |
JQL: | project = "X" and issueFunction in linkedIssuesOf("status = Closed", "is Work-Ticket to") and status changed from Resolved |
Action: | 701 Close Issue |
Run as: | admin |
Additional Code: | |
Operations: | Edit Delete |
I had faced the same earlier , I restarted the plugin service which you can find in JIRA services .
This solved my issue and the configured services worked as expected.
... ok - there is totally no service in there except the standard :(
Goto : System >> Services >> search for com.onresolve.jira.groovy.canned.admin.EscalationService:job Then click on edit then update .
Name / Class Properties Delay (mins) Mail Queue Service com.atlassian.jira.service.services.mail.MailQueueService 1 Sicherungsdienst com.atlassian.jira.service.services.export.ExportService USE_DEFAULT_DIRECTORY: true 720 Von JIRA Service Desk verwendeter Mailhandler. Darf nicht geändert oder gelöscht werden. 10.100 com.atlassian.servicedesk.squalor.email.ServiceDeskMailFetcherService handler.params: SD_MAIL_SERVER_ID=10100 popserver: Mailserver für x@x.net. Von JIRA Service Desk erstellt. 1 Audit log cleaning service com.atlassian.jira.service.services.auditing.AuditLogCleaningService 1440
Nothing to search here - and if I try to set a new it doesn't work as well with the class you mentioned :(
I believe this is the reason the escalation service is not working . Check if all modules of the Script runner plugin are enabled. OR may be @Jamie Echlin [Adaptavist] the author of Script runner can help you here.
Well, that is definitely the reason for that problem, as the service triggers the defines escalations. We have faced the same problem since several versions. What i know is: - You need the service which triggers the execution. - This service should run every minute What I do not know is: Whats the classname of the service (adding the class names above doesnt work) Maybe @Jamie Echlin [Adaptavist] Knows the right answer ;)
Hi, I am facing the same problem here. Has anyone sorted out this issue by now?
@Virgil Carcu if this is still an issue can you add the versions please.
Just cleaning things up. Problems are scheduling are fixed by upgrading to, I think it was, 3.1.3. All the scheduling code was rewritten and should be much more reliable.
