ScriptRunner: Getting list of Boards in a Project
Jürgen Talik January 11, 2023
I want to get boards connected to specific project using ScriptRunner and Jira Java API.
According to documentation there is interface called BoardManager which includes method called getBoardsForProject(long projectId). This sounds like exactly what I need but for some reason, no matter the project, it always returns null.
Here's my ScriptRunner code:
import com.atlassian.jira.board.Board
import com.atlassian.jira.board.BoardManager
def boardManager = ComponentAccessor.getComponent(BoardManager);
def b = boardManager.getBoardsForProject(12401);
return b;
When using the same project id in REST API call /rest/agile/1.0/board?projectKeyOrId=12401, I'm getting the Boards I'm expecting. I know, it is possible to use REST API calls in ScriptRunner as well, but this is something I don't want to do.
Any ideas, how to modify my script to get the needed data?
Graham Twine
February 2, 2023
//I have tried the following and all return nothing. The Rapidview service is not even returning an instnace of the service :(
import
org.apache.log4j.Level
import com.atlassian.jira.bc.ServiceOutcome
import com.atlassian.jira.board.BoardService
import com.atlassian.jira.board.store.BoardStore
import com.atlassian.greenhopper.service.rapid.view.RapidViewService
import com.atlassian.greenhopper.service.sprint.SprintService
log.setLevel(Level.DEBUG)
def boardService = ComponentAccessor.getComponent(BoardService)
def boardStore = ComponentAccessor.getComponent(BoardStore)
def rapidViewService = ComponentAccessor.getComponent(RapidViewService)
def sprintService = ComponentAccessor.getComponent(SprintService)
def projectManager = ComponentAccessor.projectManager
ApplicationUser me = ComponentAccessor.jiraAuthenticationContext.loggedInUser
String result = "<span>Hi</span>"
def out = rapidViewService.getRapidViews(me)
out.get().each {
result += "<br />$it"
projectManager.projects.each { project ->
List<Board> projectBoards = boardManager.getBoardsForProject(project.id)
result += "<br />$project -> $projectBoards"
projectBoards.each { board ->
result += "<br/>$project -> $board"
projectBoards = boardStore.getBoardsForProject(project.id)
projectBoards.each{ board ->
result += "<br />$project -> $board"
ServiceOutcome<List<Board>> outcome = boardService.getBoardsForProject(me, project.id)
projectBoards = outcome.get()
return result
Graham Twine
February 2, 2023
I have found two ways to get to these services and managers.
1)
def rapidViewService = ComponentAccessor.getOSGiComponentInstanceOfType(RapidViewService)
2)
import com.onresolve.scriptrunner.runner.customisers.JiraAgileBean
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
@WithPlugin( "com.pyxis.greenhopper.jira" )
@JiraAgileBean RapidViewService rapidViewService
I am getting useful data out of both mechanisms.
Jürgen Talik February 3, 2023
While this does return information about boards, it doesn't return a list of boards associated with each project.
All three getBoardsForProject implementations still return null.
Code I tried:
import org.apache.log4j.Level
out.get().each {
return result
 Result:
Project: TSTKB -> []
Project: ATDEV -> []
Project: AV -> []
Project: AV -> []
Project: AV -> []
Project: ATL -> []
Project: ATL -> []
Project: ATL -> []
etc
Graham Twine
February 6, 2023 edited
It just turns out this is part of Jira Agile so this is the place to do things regarding sprints, ranking, boards etc.
import com.atlassian.greenhopper.service.sprint.SprintManager
import com.atlassian.greenhopper.service.sprint.SprintIssueService
import com.atlassian.greenhopper.service.sprint.SprintQueryService
import com.atlassian.greenhopper.service.sprint.SprintHistoryService
import com.atlassian.greenhopper.service.sprint.Sprint.SprintBuilder
@JiraAgileBean SprintIssueService sprintIssueService
@JiraAgileBean SprintQueryService sprintQueryService
@JiraAgileBean SprintHistoryService sprintHistoryService
@JiraAgileBean SprintManager sprintManager
@JiraAgileBean SprintService sprintService
Graham Twine
February 6, 2023
After bumbling about a bit I have found what I think you are looking for @Jürgen Talik
import com.atlassian.jira.project.ProjectManager
import com.atlassian.greenhopper.service.ServiceOutcome
import com.atlassian.greenhopper.service.rapid.ProjectRapidViewService
import com.atlassian.greenhopper.model.rapid.RapidView
log.setLevel(Level.INFO)
@WithPlugin('com.pyxis.greenhopper.jira')
@JiraAgileBean ProjectRapidViewService projectRapidViewService
ProjectManager projectManager = ComponentAccessor.projectManager
// @FIXME Use markup builder instead
String result = ''
String[] keys = ['TSTKB', 'ATDEV', 'AV', 'ATL']
keys.each { pKey ->
Project project = projectManager.getProjectByCurrentKey(pKey)
log.info("Searching for rapid view bords that belong to ${project.name}")
result += "<h3>${project.key}</h3>"
projectRapidViewService.findRapidViewsByProject(me, project).each { outcome ->
List<RapidView> boards = ((ServiceOutcome<List<RapidView>>)outcome).value
boards.each { rv ->
result += "${rv.name}<br/>"
result += "<hr />"
return result
Like Jürgen Talik likes this
Jürgen Talik February 6, 2023 edited
Fantastic, thank you @Graham Twine! Indeed, ProjectRapidViewService was the missing piece of the puzzle!
Here is my MVP code for anyone interested:
import groovy.json.JsonOutput
ProjectManager projectManager = ComponentAccessor.projectManager;
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
Project project = projectManager.getProjectObj(12401);
log.warn("List of boards for project: ${project.getKey()}");
List<RapidView> boards = projectRapidViewService.findRapidViewsByProject(currentUser, project).value;
log.warn(JsonOutput.toJson(boards));
Edit: Optimized the code a bit.
Like 3 people like this
Graham Twine
@Jürgen Talikcan you mark this as accepted if it is the correct response
Including the filter query for each board and format into a table.
I really should be using the MarkupBuilder instad of formatting HTML in strings :(
import com.atlassian.jira.issue.search.SearchRequestManager
SearchRequestManager srManager = ComponentAccessor.getComponent(SearchRequestManager)
String result = ''
keys.each { pKey ->
String projectData = "<h3>${project.key} ${project.name}</h3>"
projectData +=
"""<table class="aui aui-table-sortable">
<thead>
<tr>
<th>Board Id</th>
<th>Board Name</th>
<th>Filter Query</th>
</tr>
</thead>
<tbody>
boards.each { rv ->
SearchRequest sr = srManager.getSearchRequestById(rv.savedFilterId)
projectData += "<tr><td>${rv.id}</td><td>${rv.name}</td><td>${sr.query}</td></tr>"
projectData += "</tbody></table>"
result += projectData
return result
Italo _Modus Create_
@Graham Twine Amazing script!
We are migrating a JIRA Server to Cloud and many business project were failing because they were used in kanban board (see limitation below)
We adapted the script to fetch all projects of business type:
// add import for
import java.util.stream.Collectors
// replace keys variable to populate with all projects with type Business
// String[] keys = ['TSTKB', 'ATDEV', 'AV', 'ATL']
String[] keys = projectManager.getProjectObjects().stream().filter(it -> it.getProjectTypeKey().getKey().equals("business")).map(it->it.getKey()).collect(Collectors.toList()).toArray()
Like Graham Twine likes this
Graham Twine
April 12, 2023
One could use some criteria such as project category or type get a list of projects instead of just adding a list.
In Scriptrunner ...
projectManager.projectObjects.findAll { project ->
project.projectTypeKey.key == "business"
}.each {
// do something with the filtered projects such as above
Chamdarig Dall March 31, 2025
Hi Team, is there any way to add values of Administrators field of a particular board to that script?
Henrique Bittencourt July 7, 2023
@Jürgen Talik
Is there any chance of getting a Jira Cloud version of this SR code?
Jürgen Talik July 10, 2023
Not from me, sorry. It would take some time to come up with that.
Trudy Claspill
Hello @Jürgen Talik
Welcome to the Atlassian community!
What version of Jira are you using?
Jürgen Talik January 12, 2023
Hi! Jira version is 8.20.10.
