ScriptRunner | Move Listener | Create Sub-task | Conditionally
Luis Tellado April 11, 2022
Can someone help with the groovy script to conditionally create a sub-task when a Story moves from one project to another? I looking to use ScriptRunner Move Listener for this.
Use Case: When a Story moves out of/from the project key "CAP" to any other project, check if sub-task (Code Review) has been created and if not, create sub-task (Code Review) which is just a standard sub-task with "Code Review" as its summary. We need to also consider if a Story is moving into project key "CAP", do not create sub-task (Code Review).
Appreciating your help and please let me know if additional details are needed.
Jorden Van Bogaert
April 12, 2022
Hi @Luis Tellado
With scriptrunner's script listener, you can use the built-in "create subtask" listener and configure it as follows:
  • Apply to the specific projects that you want the move event to create subtasks for (I included both source and destination projects as triggers)
  • Events: "Issue Moved"
  • Condition (based on your use case)
Issue eventIssue = issue
def projectsList = projects
def sourceProject
def newProject
if(projectsList[0] == eventIssue.getProjectObject().getKey()){
sourceProject = projectsList[1]
newProject = projectsList[0]
else{
sourceProject = projectsList[0]
newProject = projectsList[1]
log.info("Issue moved from ${sourceProject} to ${newProject}")
def subtasks = eventIssue.getSubTaskObjects()
def subTaskExists = subtasks.any {it.getSummary().toLowerCase().contains("code review")}
if(sourceProject == "CAP" && !subTaskExists)
return true
else {
return false
You can probably simplify it/clean it up.
  • target issue type --> choose the subtask type you want to use (needs to exist in the project)
  • Fields to copy --> as per your requirements
All the rest, I left empty.
Hope this helps
Kind regards
Jorden
Help us plant more trees
