ScriptRunner: Post-Function with file path instead of inline script
Matt October 8, 2019 edited
I'm quite new to ScriptRunner, and am wondering how to have my post-functions take a file path to the script, rather than pasting inline script.
I need the same post-function script for transitions in several workflows, so I'd rather direct each to the file path of one script rather than pasting the same inline code for each.
That way, I can update the script once rather than for each workflow I've set it up for.
When applying a custom groovy script post-function to a workflow transition, I'm met with the following menu - note the Script | File toggle over the code area isn't there!
Is there no way to give it a path to follow rather than always having to write inline script?
Edit: Well, sh*t, guess that's how new I am to this :p
Ravi Sagar _Sparxsys_
October 9, 2019
Hi @Matt
There is a field Script file just above the inline script.
Ravi
Matt October 9, 2019
Yup, I noticed as soon as I had posted this!
Sometimes there will be a script file field, other times there are the toggle buttons above the inline script area.
Would be nice if it was consistent, guess I just have to learn each form now!
Sebastian Krzewiński
Hi @Matt
As I remember if you want move your script to files (IMHO this is a very good idea) you should put it in home directory.
More information you can find in other community posts:
- https://community.atlassian.com/t5/Adaptavist-questions/Need-to-know-the-file-path-in-server-level-where-the-Script/qaq-p/728856
- https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Where-do-I-place-A-ScriptRunner-script/qaq-p/797291
Seba
Register here ⬇️
