We want to have a specific custom field "Extended visibility" with two values: "Open" and "Restricted".
Our need is the following for one project:
Is there a way to do this using ScriptRunner?
Thanks for your suggestion. It's not possible cause the security level is not well managed in our database instance. We have more than 200 projects now and scurity level has been used by some project to identify which issues should be visible in reports for customer.
So, it's not possible to use Security Level...
