I have a problem with my event listener. It is set to 1 project and all events:
CODE:
import org.apache.log4j.Logger import com.atlassian.jira.event.issue.IssueEvent import com.atlassian.jira.event.issue.AbstractIssueEventListener import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.component.ComponentAccessor MutableIssue myIssue = (MutableIssue) event.issue; log.info("[UpdateFirelight] Script fired"); def customFieldManager = ComponentAccessor.getCustomFieldManager() def customField = customFieldManager.getCustomFieldObjects(myIssue).find {it.name == 'Firelight'} if (myIssue.priority.name=='Blocker') { log.info("[UpdateFirelight] Firelight Red"); myIssue.setCustomFieldValue(customField, "Red") } if (myIssue.priority.name=='Critical') { log.info("[UpdateFirelight] Firelight Yellow"); myIssue.setCustomFieldValue(customField, "Yellow") } if (myIssue.priority.name!='Blocker' && myIssue.priority.name!='Critical') { log.info("[UpdateFirelight] Firelight Green"); myIssue.setCustomFieldValue(customField, "Green") } log.info("[UpdateFirelight] Script finished");
I can see that it runs, and without error. But I see no logs nor changes on my custom field. Anyone can help?
As I am really new to script runner, I do not get what I have to change to get it working.
I had a look at http://stackoverflow.com/a/8264451 but can not figure out how to change mine.
after you set custom filed value you should store it to database using
ComponentAccessor.getIssueManager().updateIssue(ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser(), myIssue, EventDispatchOption.ISSUE_UPDATED, false)
I got it working with your suggestion. I needed to adjust some other things, but it works now! Thanks
Register today
