ScriptRunner behaviour and Select List (cascading)
SergioA August 28, 2024
Hi, I'm working on a simple behaviour that changes the value of a field based on the value of a Select List (cascading) field.
At this moment, the behaviour looks like this:
const changedField = getChangeField()
console.log(`New value is ${JSON.stringify(changedField.getValue(), null, 2)}`)
And it's configured to be executed on load and on init events, in the create view.
When I change the value of any field of the creation form, I can see the logs in the browser's console:
But when I change the value of both fields of the Select List (cascading) fields, I can see no logs, like if the on change event is not being triggered.
Does ScriptRunner's Behaviours provide support for this type of fields?
Ben
August 28, 2024
Hi Sergio,
Unfortunately cascading lists are not yet supported by ScriptRunner Behaviours.
A list of supported fields can be found here
https://docs.adaptavist.com/sr4jc/latest/features/behaviours/behaviours-supported-fields-and-products#:~:text=your%20selected%20view%3A-,Create%20View%20Supported%20Fields,-Field%20/%20methods
ScriptRunner Behaviours is reliant on Atlassian's UI Modifications API. Once cascading lists are supported by the UI Modifications API they will be available within Behaviours.
https://developer.atlassian.com/platform/forge/apis-reference/jira-api-bridge/uiModifications/#supported-fields-per-view
I hope this information helps and appreciate it's not the ideal response you were looking for!
Ben
Many thanks for your quick response, Ben.
Breanna Byron November 15, 2024
The documentation does not reflect that though. I would expect the field cascading list to be... well listed.
