ScriptRunner disabled
Dominik October 27, 2016
I've created a Raw XML Module Built-In Script with following content:
<web-item key='x-y-webitem' name='Create Change Package' section='operations-attachments' weight='70' class='script:/
import com.atlassian.jira.web.action.JiraWebActionSupport;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class Output extends JiraWebActionSupport{
private static final Logger log = LoggerFactory.getLogger(CreateChangePackage.class);
public String doExecute() throws Exception {
log.debug("Execute!");
return "OK";
  <label>Test</label>
  <condition class='script:jiraHelper.project.key in ["DTP"]' />
  <styleClass> sr-trigger-flag</styleClass>
  <link linkId='x-y-webitem-link'></link>
</web-item>
The Web-Item was visible and I have clicked on it.
Afterwards the ScriptRunner plugin was disabled.
What can I do to get the Plugin run?
I've already restarted JIRA.
Also tried to uninstall and reinstall the ScriptRunner Plugin.
And last but not least also deleted the groovyrunner*.jar file in the $JIRA_HOME/plugins/.osgi-plugins dir
I can't update any scripts I have created in the Administration - Script Fragments because the menu isn't shown anymore.
Is there a way to edit them in the file system or anywhere else?
Since the Error and the disabled ScriptRunner Plugin all Menus of the Plugin aren't available. :|
Thank You
Error log:
2016-10-26 11:30:00,241 UpmAsynchronousTaskManager:thread-2 ERROR USER 1047x2182x1 1nh21a1 10.219.128.88 /rest/plugins/1.0/installed-marketplace [c.a.plugin.manager.DefaultPluginManager] There was an error loading the descriptor 'Create Change Package' of plugin 'com.onresolve.jira.groovy.groovyrunner'. Disabling.
com.atlassian.plugin.PluginParseException: Could not load class: script:/ import com.atlassian.jira.web.action.JiraWebActionSupport; import org.slf4j.Logger; import org.slf4j.LoggerFactory; public class Output extends JiraWebActionSupport{ private static final Logger log = LoggerFactory.getLogger(Output.class); public String doExecute() throws Exception { log.debug("Execute!"); return "OK"; } }
	at com.atlassian.plugin.module.LegacyModuleFactory.getModuleClass(LegacyModuleFactory.java:37)
	at com.atlassian.plugin.descriptors.AbstractModuleDescriptor.loadClass(AbstractModuleDescriptor.java:199)
	at com.atlassian.plugin.descriptors.AbstractModuleDescriptor.enabled(AbstractModuleDescriptor.java:446)
	at com.atlassian.plugin.web.descriptors.AbstractWebFragmentModuleDescriptor.enabled(AbstractWebFragmentModuleDescriptor.java:106)
	at com.atlassian.plugin.web.descriptors.DefaultWebItemModuleDescriptor.enabled(DefaultWebItemModuleDescriptor.java:72)
	at com.atlassian.plugin.web.descriptors.DefaultAbstractWebFragmentModuleDescriptor.enabled(DefaultAbstractWebFragmentModuleDescriptor.java:35)
	at com.atlassian.plugin.manager.DefaultPluginManager.notifyModuleEnabled(DefaultPluginManager.java:1991)
	at com.atlassian.plugin.manager.DefaultPluginManager.enableConfiguredPluginModule(DefaultPluginManager.java:1738)
	at com.atlassian.plugin.manager.DefaultPluginManager.onPluginModuleAvailable(DefaultPluginManager.java:746)
	... 2 filtered
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:36)
	at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$1$1.run(AsynchronousAbleEventDispatcher.java:48)
	at com.google.common.util.concurrent.MoreExecutors$DirectExecutorService.execute(MoreExecutors.java:299)
	at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:107)
	at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:160)
	at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:79)
	at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:73)
	at com.atlassian.plugin.osgi.factory.ModuleDescriptorServiceTrackerCustomizer.addingService(ModuleDescriptorServiceTrackerCustomizer.java:41)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:864)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:894)
	at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:932)
	at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:793)
	at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:543)
	at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4419)
	at org.apache.felix.framework.Felix.registerService(Felix.java:3423)
	at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:346)
	at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:320)
	... 3 filtered
	at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoCachedMethodSite.invoke(PojoMetaMethodSite.java:192)
	at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:56)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:141)
	at com.onresolve.scriptrunner.fragments.FragmentsManager.register(FragmentsManager.groovy:259)
	at com.onresolve.scriptrunner.fragments.FragmentsManager.register(FragmentsManager.groovy)
	at com.onresolve.scriptrunner.fragments.IFragmentsManager$register.call(Unknown Source)
	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:48)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:113)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:133)
	at com.onresolve.scriptrunner.canned.common.fragments.CustomRawXmlDescriptorScript$_doScript_closure2.doCall(CustomRawXmlDescriptorScript.groovy:109)
	... 3 filtered
	at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:93)
	at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:325)
	at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:294)
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1021)
	at groovy.lang.Closure.call(Closure.java:426)
	at groovy.lang.Closure.call(Closure.java:442)
	at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2030)
	at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2015)
	at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2056)
	at org.codehaus.groovy.runtime.dgm$162.invoke(Unknown Source)
	at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:274)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:125)
	at com.onresolve.scriptrunner.canned.common.fragments.CustomRawXmlDescriptorScript.doScript(CustomRawXmlDescriptorScript.groovy:103)
	at com.onresolve.scriptrunner.canned.CannedScript$doScript.call(Unknown Source)
	at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.validateAndRunCannedInternal(ScriptRunnerImpl.groovy:421)
	... 3 filtered
	at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:210)
	at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:59)
	at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.runCanned(ScriptRunnerImpl.groovy:375)
	... 3 filtered
	at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSite.invoke(PogoMetaMethodSite.java:169)
	at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.call(PogoMetaMethodSite.java:71)
	at com.onresolve.scriptrunner.fragments.FragmentsManager$_registerFragments_closure1.doCall(FragmentsManager.groovy:106)
	... 3 filtered
	at com.onresolve.scriptrunner.fragments.FragmentsManager.registerFragments(FragmentsManager.groovy:105)
	at com.onresolve.scriptrunner.fragments.FragmentsManager.onFullSystemStart(FragmentsManager.groovy:376)
	... 3 filtered
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1212)
	at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnCurrentN(ScriptBytecodeAdapter.java:82)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser.this$dist$invoke$1(FullSystemStartedInitialiser.groovy)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser$FullSystemInitialiser.methodMissing(FullSystemStartedInitialiser.groovy)
	... 3 filtered
	at groovy.lang.MetaClassImpl.invokeMissingMethod(MetaClassImpl.java:938)
	at groovy.lang.MetaClassImpl.invokePropertyOrMissing(MetaClassImpl.java:1261)
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1214)
	at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:69)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:158)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser$FullSystemInitialiser.<init>(FullSystemStartedInitialiser.groovy:102)
	... 3 filtered
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:83)
	at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:105)
	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallConstructor(CallSiteArray.java:60)
	at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:110)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:247)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser$1.create(FullSystemStartedInitialiser.groovy:37)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser$1.create(FullSystemStartedInitialiser.groovy)
	at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:325)
	at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143)
	at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112)
	at com.atlassian.util.concurrent.Supplier$get.call(Unknown Source)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser.onSystemStartPhase(FullSystemStartedInitialiser.groovy:66)
	... 2 filtered
	at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:52)
	at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:64)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:166)
	at com.onresolve.scriptrunner.runner.FullSystemStartedInitialiser.onStart(FullSystemStartedInitialiser.groovy:56)
	at com.onresolve.scriptrunner.fragments.JiraFragmentsManager.super$2$onStart(JiraFragmentsManager.groovy)
	... 3 filtered
	at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuperN(ScriptBytecodeAdapter.java:132)
	at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnSuper0(ScriptBytecodeAdapter.java:152)
	at com.onresolve.scriptrunner.fragments.JiraFragmentsManager.onStart(JiraFragmentsManager.groovy:45)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$4.consume(DefaultLifecycleManager.java:310)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$4.consume(DefaultLifecycleManager.java:306)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyLifecyleAware(DefaultLifecycleManager.java:344)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyOnStartIfStartedAndEnabled(DefaultLifecycleManager.java:304)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.access$300(DefaultLifecycleManager.java:50)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$3.evaluate(DefaultLifecycleManager.java:261)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager$3.evaluate(DefaultLifecycleManager.java:257)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyLifecycleAwares(DefaultLifecycleManager.java:286)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.notifyStartableLifecycleAwares(DefaultLifecycleManager.java:255)
	at com.atlassian.sal.core.lifecycle.DefaultLifecycleManager.onPluginEnabled(DefaultLifecycleManager.java:172)
	... 2 filtered
	at com.atlassian.plugin.manager.DefaultPluginManager.broadcastIgnoreError(DefaultPluginManager.java:2081)
	at com.atlassian.plugin.manager.DefaultPluginManager.enableDependentPlugins(DefaultPluginManager.java:1228)
	at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:1188)
	at com.atlassian.jira.plugin.JiraPluginManager.addPlugins(JiraPluginManager.java:150)
	at com.atlassian.plugin.manager.DefaultPluginManager.scanForNewPlugins(DefaultPluginManager.java:903)
	at com.atlassian.plugin.manager.DefaultPluginManager.installPlugins(DefaultPluginManager.java:821)
	at com.atlassian.jira.plugin.JiraPluginManager.installPlugins(JiraPluginManager.java:168)
	... 3 filtered
	at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
	at com.sun.proxy.$Proxy323.installPlugins(Unknown Source)
	... 3 filtered
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207)
	at com.sun.proxy.$Proxy1281.installPlugins(Unknown Source)
	at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:143)
	at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:138)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:25)
	at com.atlassian.jira.DefaultHostContextAccessor.doInTransaction(DefaultHostContextAccessor.java:34)
	... 2 filtered
	at com.sun.proxy.$Proxy180.doInTransaction(Unknown Source)
	... 2 filtered
	at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:21)
	... 2 filtered
	at com.sun.proxy.$Proxy1309.execute(Unknown Source)
	at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifacts(AbstractPluginInstallHandler.java:137)
	at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifact(AbstractPluginInstallHandler.java:123)
	at com.atlassian.upm.core.install.JarPluginInstallHandler.installPluginInternal(JarPluginInstallHandler.java:52)
	at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installPlugin(AbstractPluginInstallHandler.java:64)
	at com.atlassian.upm.core.install.DefaultPluginInstallationService.execute(DefaultPluginInstallationService.java:117)
	at com.atlassian.upm.core.install.DefaultPluginInstallationService.install(DefaultPluginInstallationService.java:91)
	at com.atlassian.upm.install.UpmPluginInstallationService.install(UpmPluginInstallationService.java:97)
	at com.atlassian.upm.core.rest.resources.install.InstallTask.installFromFile(InstallTask.java:156)
	at com.atlassian.upm.core.rest.resources.install.InstallFromUriTask$1.apply(InstallFromUriTask.java:89)
	at com.atlassian.upm.core.rest.resources.install.InstallFromUriTask$1.apply(InstallFromUriTask.java:53)
	at com.atlassian.upm.api.util.Either$Right.fold(Either.java:173)
	at com.atlassian.upm.core.rest.resources.install.InstallFromUriTask.executeTask(InstallFromUriTask.java:52)
	at com.atlassian.upm.core.rest.resources.install.InstallTask.run(InstallTask.java:81)
	at com.atlassian.upm.core.async.AsynchronousTaskManager.executeTask(AsynchronousTaskManager.java:124)
	at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:102)
	at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:99)
	at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:42)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: script:/ import com.atlassian.jira.web.action.JiraWebActionSupport; import org.slf4j.Logger; import org.slf4j.LoggerFactory; public class Output extends JiraWebActionSupport{ private static final Logger log = LoggerFactory.getLogger(Output.class); public String doExecute() throws Exception { log.debug("Execute!"); return "OK"; } } not found by com.onresolve.jira.groovy.groovyrunner [205]
	at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1532)
	at org.apache.felix.framework.BundleWiringImpl.access$400(BundleWiringImpl.java:75)
	at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1955)
	at java.lang.ClassLoader.loadClass(Unknown Source)
	at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1844)
	at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor.loadClass(BundleClassLoaderAccessor.java:45)
	at com.atlassian.plugin.osgi.factory.OsgiPluginInstalledHelper.loadClass(OsgiPluginInstalledHelper.java:56)
	at com.atlassian.plugin.osgi.factory.OsgiPlugin.loadClass(OsgiPlugin.java:207)
	at com.atlassian.plugin.module.LegacyModuleFactory.getModuleClass(LegacyModuleFactory.java:24)
	... 273 more
Dominik November 13, 2016
database table value deleted
Roberto Saltini
I have the same issue, in which table is the value to be delted?
Like • Martin Greksa likes this
Martin Greksa
March 7, 2020
I had a similar issue. I was able to resolve it by updating the following value in database:
UPDATE "AO_4B00E6_STASH_SETTINGS"
SET "SETTING" = '[]'
WHERE "ID"= '1'
'[]' - because it seems that it is default value in empty scriptrunner
JIRA 7.1.9
ScriptRunner 4.3.12
The Error was also in SrciptRunner version 4.3.10 (I think it was 10 or 9) because I tried to reinstall the Plugin after the Error
Thanos Batagiannis [Adaptavist]
October 27, 2016
Hi Dominic,
ScriptRunner and JIRA versions ?
