ScriptRunner: issue with Transition parent when all sub-tasks resolved
Aleksei Klimkin
Hi everyone.
We have scriptrunner and use its post-function named "Transition parent when all sub-tasks are resolved".
The final status after parent's transition is not a final status in the workflow, meaning we don't need to set the resolution on the parent. Or, to be more precise, we need to leave it unresolved.
However, when I use the aforementioned post-function (I only choose the necessary transition, without setting any conditions, and leave the "Resolution" field value None) I get this error and it doesn't allow me to update the function.
What could be the problem with that?
Thanks in advance!
Leonard Chew
December 5, 2019
Resolution "None" should be correct in my opinion, but if you are forced to set a value on that screen, this might be a workaround:
  1. select any other resolution for the postfunction to work
  2. add a "clear resolution" with a postfunction on the transition of the parent
Alternatively:
  • Try a custom script on your postfunction and script the transition without setting the resolution.
Leonard Chew
December 5, 2019
Before trying the above... check if you have configured a transition screen with a mandatory resolution field.
Aleksei Klimkin
Yes, I thought about that too.
I am afraid this might cause side-effects too. For example, if you're using some filter to find issues resolved in the last week, this workaround might cause the issue to appear in that search because the resolution for that issue was set during last week.
Thought I haven't tried this yet.
Aleksei Klimkin
No, the transition 81 for the parent uses no screen.
Roberto Marquez Bittencourt April 2, 2020 edited
Something new about that? I have the same error. I've updated the Script Runner version in our test enviroment and have the same results.
Roberto Bittencourt
Aleksei Klimkin
Still doesn't work.
I've had to write my own script for this transition.
Perhaps you may find it useful.
import com.atlassian.jira.workflow.*
import com.atlassian.jira.util.JiraUtils
def wtu = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class)
def userKey = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser().getKey()
def parent = issue.getParentObject()
def subtasks = parent.getSubTaskObjects()
def categories = subtasks*.status.statusCategory
if (parent.getStatus().getSimpleStatus().getName() == "In Progress" &&
    categories.every {cat -> cat.getName() == "Complete"}) {
       def mp = parent as MutableIssue
       wtu.setIssue(mp)
       wtu.setUserkey(userKey)
       wtu.setAction(81)
       if (wtu.validate()) {
            wtu.progress()
This is the script which transitions parent issue from status "In Progress" through the transition with id 81 when the status category for all sub-tasks is "Complete", i.e. work finished.
Of course you need to adjust it a little bit based on your needs.
Like • Nicolas Desessart likes this
Damian Wodzinski
December 4, 2019
Is the "None" the correct resolution? Maybe try to pick "Unresolved" from the list?
Aleksei Klimkin
Unfortunately, there's no Unresolved in there
Damian Wodzinski
December 5, 2019
I think somebody designed it that way. Maybe try workaround? Add another status matching the state if the parent: "Subtasks done", or simply add "Unresolved", but this may cause some confusion when trying to search using JQL, as there will be two of the same resolutions.
Aleksei Klimkin
Well, actually nope, because it was working fine previously. I don't even know when it started showing this error, to be honest.
Well, adding another resolution seems a bit worrying for me, since there're a lot of filters used in jira for this purpose, and basically Unresolved means that resolution is not set for the issue.
So if I set the Resolution to this new "Unresolved" I am afraid that it might cause side-effects.
The most important question is why is this now not working though it used to work in the past.
Hope to get some response from Adaptivist ScriptRunner members.
Aleksei Klimkin
Anyway, thanks for your help!
Damian Wodzinski
December 5, 2019
You should also check the project settings to see, if "Resolution" field is required. Maybe it's blocking you there.
