ScriptRunner script doesn't run
ganna_kyselevych December 20, 2023 edited
I need to make a field SEO_Type of asset visible when the Label_BM filed is BM_SEO and invisible when the label is any other during the ticket creation.
I use the following script and it makes a field SEO_Type of asset invisible in any case:
const labelsBMField = getFieldById("customfield_12525");
const seoTypeOfAssetField = getFieldById("customfield_12702");
seoTypeOfAssetField.setVisible(true);
const labelsBMValue = labelsBMField.getValue()?.name;
if (labelsBMValue == 'BM_SEO') {
} else {
seoTypeOfAssetField.setVisible(false);
What is wrong?
Mohammed Aamer Khan
December 20, 2023
@ganna_kyselevych
You have to store value as string to compare. Let me know if it works
const labelsBMValue = labelsBMField.getValue()?.name.toString(); //Converts value to string
If above doesnt work Try below code
const labelsBMValue = labelsBMField.getValue().toString(); //Converts value to string
ganna_kyselevych December 21, 2023
Unfortunately, nothing changed 😞
First option:
function updateVisibility() {
if (labelsBMValue === 'BM_SEO') {
} else {
labelsBMField.onChange((fieldId, newValue, oldValue) => {
updateVisibility();
updateVisibility();
Second option:
} else {
updateVisibility();
updateVisibility();
Register here ⬇️
