Scripted Field Custom Template
Tobias Brunner (Admin Account) August 15, 2016
I want to have a custom template in a script field which does some calculation. Basically the script outputs the $value in seconds and I'm able to use the form "$getPrettyDuration.call($value)" (as found in the documentation). But I'd like to convert the seconds into hours, but not changing $value from seconds into hour, just for displaying.
Is there a reference what can be done in this "Custom Template" field? Is this just Groovy script? Is there more documentation available for this field?
  • Version of JIRA: 7.1.9
  • What version of ScriptRunner are you using? 4.3.5
Nic Brough -Adaptavist-
August 15, 2016
The templates are for telling JIRA how to handle the data that is in them.  They're not for doing the formatting of the output.
Your scripted field should be outputting $value in the format you want to see it, not trying to format it on the way out.  If you really do need the $value in seconds as well, you'll want a separate field to do that, as the content of the field is different.
Not sure about that, the example in the ScriptRunner documentation (https://scriptrunner.adaptavist.com/latest/jira/recipes/scriptfields/workRemainingInLinkedIssues.html) also does this using
When saving it as a number instead of free text I think indexing of the field makes more sense, also when using this field in searches for sorting it's easier when it's saved as number. Or am I wrong here?
August 15, 2016
Yes, it outputs the value that is desired.
You're right about sorting, you want numeric for that.  The problem here is that you're asking for two values to come out of one thing.  For that to work, you need code inside jira to do it - your script could, in theory, output both, but JIRA would need to understand "show value 1, while search/sorting on value 2".  The original estimate field is built that way, but ScriptRunner only has templates for single value outputs - text OR numbers OR dates etc.
August 15, 2016
That said, might be worth asking Adaptavist to add a new template for "length of time" - store seconds, display pretty.  I will poke the team and see if we've already got an issue raised for it.
Thanks Nic for clarification. The idea with the two values won't be too bad. But what's against doing it like the function getPrettyDuration? Something like an output formater? Are there any other functions available like getPrettyDuration?
August 15, 2016
There's nothing against using the pretty duration thing, it works fine.  The problem is that you're trying to work with two values in one field.
I don't really need two values. Let me rephrase my original question:
  • Save one value (here in seconds)
  • Format the output (here in hours)
The getPrettyDuration is not configurable (afaik), that means it always outputs it in the "pretty" format designed by Atlassian, which isn't what I want. All I want is to just convert the seconds stored in the index in hours for display purposes.
One questions stays: What functions are available for Custom Templates, besides the getPrettyDuration? Is there anywhere a documentation available?
August 15, 2016
Then you build a custom field that has an output of <value field>/3600 (maybe with some rounding)
Ok, that would make it... So do I understand this correctly that there are no more functions available for Custom Templates than getPrettyDuration?
August 15, 2016
Yes
Ok, thanks
JamieA
August 29, 2016
I'll take a risk here and disagree with Nic.
Templates are precisely for formatting the value returned by the script field code for display to use the user.
You can convert to hours using code as shown below.
Caution: You must use the number range indexer for the field, otherwise ScriptRunner will convert the return value to whatever is suitable for the chosen indexer.
image2016-8-30 10:30:50.png
(for detail see https://answers.atlassian.com/download/attachments/40348731/image2016-8-30%2010%3A30%3A50.png?version=1&modificationDate=1472549439634&api=v2)
There is a bunch of other stuff available although not well documented.
randybishop
September 30, 2016
II have the same question as Tobias. Is there any documentation for what methods are available for custom templates? I've been scouring the internet to no avail,
Methods look to be formatted as Velocity templates but I can't find documentation anywhere.
JamieA
October 1, 2016
Yes, they are velocity templates. I tried to answer your question here: https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html#comment-2928282368
Learn more
