Scriptrunner Listener on epic link
Mickaël ORSOLINO
I would like to get a listener on the issue without epic link.
I don't find the way to find the epic link class.
Could you help me?
Thank you for your help.
Mickael
SITTER Adrien
April 10, 2020
Hello @Mickaël Orsolino
I am not sure of what you are asking.
If you have a Listener on an IssueEvent you will have an acces to the issue created, updated, assigned, revolved etc...
From there you can retrieve the Epic Link value this way:
def issue = event.issue
def customFieldManager = ComponentAccessor.customFieldManager
def epicLinkField = ComponentAccessor.customFieldManager.getCustomFieldObjectsByName('Epic Link')[0];
def epicLinkValue = issue.getCustomFieldValue(epicLinkField)
if (!epicLinkValue)
// Do something with issue which has no Epic Link
else
// Do something with issue which has an Epic Link
//For exemple retrieve Epic issue
def epicIssue = issueManager.getIssueObject((String)epicLinkValue)
Adrien
Mickaël ORSOLINO
Hi Adrien,
I try to catch each issue created without epic link. I will try your answer.
Mickael
SITTER Adrien
April 10, 2020
Then you should just the code I posted with a Listener on event IssueCreated
Adrien
SERVER
