Is there a way to use postfunctions to clone a subtask when a subtask transitions to a certain status.
For some reason scriptrunner doesn't allow for the selection of subtasks when using the clone postfunction.
Use Case:
When a subtask enters a failed status, we want a bug subtask created under the same parent.
Hi, @Duane Cronkite
Maybe Jira Automation? :)
Ok, ok, just joking, I remember, you use server )
As for your answer, it's not a simple task, because script needs to know, what fields must be set. Simple version can create basic sub-task with needed issue-type, summary, description and assignee, but copying other custom fields is very tricky case.
lol!
would it be easy if we only copied over:
Well, I think, it will help
* Created 2023.
* @author Evgeniy Isaenkov
* @github https://github.com/Udjin79/SRUtils
import com.atlassian.jira.config.ConstantsManager
import com.atlassian.jira.issue.IssueManager
IssueManager issueManager = ComponentAccessor.getIssueManager()
ConstantsManager constantsManager = ComponentAccessor.getConstantsManager()
MutableIssue issue = issue as MutableIssue
MutableIssue parentIssue = issueManager.getIssueObject(issue.key)
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// Set exact name of sub task you're trying to create
String issueType = "Sub-Bug"
MutableIssue newIssue = ComponentAccessor.getIssueFactory().getIssue()
newIssue.setProjectObject(issue.getProjectObject())
newIssue.setIssueType(constantsManager.allIssueTypeObjects.findByName(issueType))
newIssue.setSummary("BUG: preface")
newIssue.setDescription(issue.description)
newIssue.setAssignee(issue.assignee)
newIssue.setReporter(user)
newIssue.setLabels(null)
newIssue.setComponent(null)
newIssue.setPriorityId('3')
newIssue.setDueDate(null)
ComponentAccessor.issueManager.createIssueObject(user, newIssue)
ComponentAccessor.subTaskManager.createSubTaskIssueLink(parentIssue, newIssue, user)
okay it looked like it successfully created a bug but the bug is somehow being listed as a subtask of a subtask. It is not appearing as a subtask on the parent.
TP-168 test 2 is a subtask which is strange that its appearing like its the bug subtask parent.
and for the summary what I meant was Bug: (clone summary of the source ticket).
So Bug: is the preface before the source summary if that makes sense.
I didn't check if description copied over yet.
and I appreciate all the help!
Found problem.
This is working (at least on my instance):
* Created 2023.
package Examples.Postfunctions
MutableIssue parentIssue = issueManager.getIssueObject(issue.parentObject.key)
newIssue.setSummary("BUG: ${issue.summary}")
once again you made my day! I'll send you a connect on Linkedin! A++++
@Evgenii : Is there a way to add a "link" between the source and created subtask to the code.
"Relates to" link will work.
Hi, @Duane Cronkite
It depends from your environment, IDs of link types can differ from mine.
You can use such code (adopted to your environment, of course):
// Set user, that will link issues
// Set inward or outward link
Long sequence = 1L
// Set link type ID
Long issueLinkTypeId = 10000L
ComponentAccessor.issueLinkManager.createIssueLink(fromIssue.id, toIssue.id, issueLinkTypeId, sequence, user)
received this error:
The script could not be compiled:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script668.groovy: 45: The current scope already contains a variable of the name user @ line 45, column 17. ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() ^
I added this link code directly to the bottom of the other code above. I tried removing the user piece etc but couldn't figure out how to get it to work.
Hi, @Duane Cronkite
What's the sense in it? This are 2 subtasks for one issue.
Anyway, it can be made with something like this:
* Created 2023.
Long sequence = 1L
// Set link type ID
ComponentAccessor.issueLinkManager.createIssueLink(issue.id, newIssue.id, issueLinkTypeId, sequence, user)
