Im trying to add additional top menu to the JIRA top navigation bar as described in this solution"
1. Add Web item to the top bar
2. Add web section to previous web item (location is previous web item)
3. Add more web items to previous section (location is previous web section)
My web section is not showing - Not sure what Im doing wrong. Help is very appreciated
Hi, I'm having the same issue when adding a web item. The sections I'm seeing in the dropdown menu when creating a web item don't match the locations I see in the fragment locator.
Where are you trying to add the web item ?
Can you share the config and where you are expecting the menu item to be added ?
Actually, my plans have changed, I am trying to create a condition that if the pull request on the bitbucket page is open not merged, then the web item should be visible. How would you check the text on a page if it contains the word "Merged"?
