Scriptrunner - assignement in workflow
Arthur SALMON
Hi Community,
I have scripts which are assigning users based on custom field values.
Those scripts are working and assigning the user but, for some reason, I have some users which are not correctly assigned and I don't know why.
For example, based on this script :
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.comments.CommentManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.user.UserUtils;
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
def String m_assignee = 'Unassigned';
def cfIssueType = issue.issueType.name;
if(cfIssueType == "Task"){
def cfEntity = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Entity");
def cfEntitySwitch = issue.getCustomFieldValue(cfEntity) as LazyLoadedOption
switch(cfEntitySwitch){
case 'France':
m_assignee = 'john.doe';
break;
case 'US':
m_assignee = 'jack.jones';
break;
default:
m_assignee = 'john.smith';
break;
issue.setAssigneeId(m_assignee);
 In that script, users jack.jones and john.smith will be assigned replacing their username by the full name but for john.doe it's still the username which is display in the assignee field and because of that, the user is not notified and cannot execute the actions relatives to is assignee role.
Any idea why I have that ?
Thanks in advance,
Martin Bayer _MoroSystems_ s_r_o__
Hi @Arthur SALMON , does john.doe have Assignable permission set?
SERVER
VERSION
8.13.2
Register today
