I have had a number of Scriptrunner behaviors and listeners running for a while with no issue. However, we had an issue with AWS and had to deploy our instance to a new stack. Now all of the Scriptrunner behaviors and listeners won't work. They're all still there with the correct settings but not firing. Any idea if I need to change anything in Jira to get them working again?
How did you migrate to new stack ?
Did you try to disable/enable the app ? Are all module enable in the app ?
Is your app licensed ?
Regards
Save your spot
