Scriptrunner behaviour for duplicate custom field
Mohamed Mehdi Mrad August 26, 2021
Im looking for a Scriptrunner behaviour to find out if a custom field already exists, If it exists when the issue is created it shouldnt be added to avoid duplicate issues.
Thank you.
Tom Lister
Hi @Mohamed Mehdi Mrad
I think that a string search of all issue summaries when an issue is created will not perform well.
How big a problem is this? Is it service desk?
Mohamed Mehdi Mrad September 3, 2021
I need to check only per project if an issue with the same summary already exists. Im still looking for a method to find out
DPKJ
Welcome to the community.
Can you elaborate here, because,
  • Fields on issue never duplicated.
  • That means that each issue with have only field with one name.
  • So I think you don't need do anything special here.
thank you for your answer,
I mean on different issues. For example, I want to check if the same summary exists on  another issue, if it is so the new one doesn't get created.
Register here ⬇️
