Scriptrunner listener doesn't work
Volodymyr
September 13, 2023 edited
Hi there,
How does the script work?
The listener checks if the issue has an Epic and if so, checks all the issues in it. Sums the time for field "Original Estimate" from all issues and sets the sum in the Epic's field.
I have a script that I finished 2 days ago and tested it on all scenarios. The script worked as it should in each test and stopped working the next day, namely, everything is the same as before in the logs, but the specified time does not appear in the epic. The field is on the screen, everything is in order with the permissions. Nothing has changed in this regard.
You can see from the logs that the value appears in the epic, but if you immediately check it through the Scriptrunner console, then the epic has a value of 0.
Maybe someone has thoughts about what I did wrong.
If you have any thoughts on how to improve the script, please let me know.
Thank you.
Edit: The listener works for 3 events (issue created, updated, deleted)
import com.atlassian.jira.event.type.EventType
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
// Curent issue and "Epic Link" field
def issue = event?.issue
def cfEpicLink = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(14500)
log.warn("The issue type is ${issue.issueType.name}, the issue summary is \"${issue.summary}\"")
// If issue type is Epic or it doesn't have Epic Link - exit the script
if (issue.getIssueTypeId() == '6' || !issue.getCustomFieldValue(cfEpicLink)) {
    return
log.warn('Inside the listener')
// Epic of the issue and current user
def epicOfIssue = issue.getCustomFieldValue(cfEpicLink) as MutableIssue
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// Managers
def issueManager = ComponentAccessor.getIssueManager()
// Temporary variable for the sum of values from "Original Estimate" field.
Long originalEstimateTotal = 0
// If the issue is created with the value for "Epic Link"
if (event?.getEventTypeId() == EventType.ISSUE_CREATED_ID) {
    !issue.getOriginalEstimate() ?: (originalEstimateTotal += issue.getOriginalEstimate())
// Managers for JQL search
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService)
// JQL query and Search to retrieve all issues in Epic
def query = jqlQueryParser.parseQuery("issueFunction in issuesInEpics(\'key = ${epicOfIssue.getKey()}\')")
def search = searchService.search(currentUser, query, PagerFilter.getUnlimitedFilter())
def searchResults = search.getResults().findAll()
searchResults?.each {
    !it.getOriginalEstimate() ?: (originalEstimateTotal += it.getOriginalEstimate())
if (epicOfIssue.getOriginalEstimate() == originalEstimateTotal) {
    log.warn("The values ARE the same: ${epicOfIssue.getOriginalEstimate() == originalEstimateTotal}, so make no change.")
    log.warn("epic's original estimate = " + epicOfIssue.getOriginalEstimate())
} else if (epicOfIssue.getOriginalEstimate() != originalEstimateTotal) {
    log.warn("The values are NOT the same: ${epicOfIssue.getOriginalEstimate() != originalEstimateTotal}, so make the change.")
    log.warn("BEFORE - epic's original estimate = " + epicOfIssue.getOriginalEstimate())
    log.warn("BEFORE - originalEstimateTotal = " + originalEstimateTotal)
epicOfIssue.setOriginalEstimate(originalEstimateTotal)
    epicOfIssue.setEstimate(0)
    issueManager.updateIssue(currentUser, epicOfIssue, EventDispatchOption.ISSUE_UPDATED, false)
    log.warn("AFTER - epic's original estimate = " + epicOfIssue.getOriginalEstimate())
    log.warn("AFTER - originalEstimateTotal = " + originalEstimateTotal)
log.warn('Outside the listener')
log.warn("originalEstimateTotal = " + originalEstimateTotal)
Volodymyr
I found the answer.
I thought "setEstimate()" method was only responsible for "Remaining Estimate", but it turns out it also clears "Original Estimate".
As soon as I commented out this line, it started working as before.
Volodymyr
Those are examples of logs
and when I immediately check the result in the console, I see this:
Register now
