Scriptrunner listener: get current issue data
Christian Schneider
February 2, 2022 edited
Dear community,
Question: How do I get the data of the current issue, for with an event fired in a  Scriptrunner listener?
Background: I am developing a little groovy script to send issue-data to a sharepoint list. I did the development in the "Groovy Console" of the "JIRA MISC WORKFLOW EXTENSIONS"-App. This console is very handy, as one can test the script against an existing issue.
My code is working perfectly fine in the JMWE-environment.
Unfortunately, I need to use a Scriptrunner listener, because I want to run my script on certain events. Scriptrunner handles things slightly different and I am struggling at the very beginning: how do I get the data of the current issue, for witch an event fired? What do I need to "import" to have access on the current issue?
My code:
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.RESTClient
import java.time.LocalDateTime
def issueKey = issue.getAsString("issuekey")
def issueStatus = issue.getAsString("status")
def issueTitle = issue.get("summary")
def issueDescription = issue.get('description')
def issueComment = issue.getAsString("comment")
def issueStartDate = issue.getAsString("customfield_10705")
def issueResolutionDate = issue.get("resolutiondate")
//log.info "${issueKey} --- ${issueStatus} --- ${issueTitle} --- ${issueDescription} --- ${issueStartDate} --- ${issueResolutionDate}"
//log.info "${issueComment}"
Any help or link to the documentation is very much appreciated.
Fabio Racobaldo _Herzum_
Hi @Christian Schneider ,
you need to retrieve your issue first and then any field associated. Try the following code :
Issue issue = event.getIssue()
def issueKey = issue.getKey()
def issueStatus = issue.getStatus().getName()
def issueTitle = issue.getSummary()
def issueDescription = issue.getDescription()
def issueResolutionDate = issue.getResolutionDate()
 Please take a look to the following API in order to get available methods https://docs.atlassian.com/software/jira/docs/api/8.5.1/index.html?com/atlassian/jira/issue/Issue.html
For comments, you need the following API https://docs.atlassian.com/software/jira/docs/api/8.5.3/com/atlassian/jira/issue/comments/CommentManager.html
Hope this helps,
Fabio
Christian Schneider
February 2, 2022
Dear @Fabio Racobaldo _Herzum_
thank you very much for your quick input. This works perfectly fine to get the Issue and field associated.
Regarding comments:
I did not yet fully understand the documentation under the provided link. Do I have to add this?
import com.atlassian.jira.issue.comments.CommentManager
def issueComment = issue.getComments()
Does not seem to work, as no matching method can be found.
Regarding custom fields for my issueStartDate-field:
Same question: this is not correct, is it?
import com.atlassian.jira.issue.customfields
def issueStartDate = issue.getValue("customfield_10705")
for comments and your field value, try the following code :
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.comments.Comment;
import com.atlassian.jira.issue.comments.CommentManager;
import com.atlassian.jira.issue.fields.CustomField;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField myField = customFieldManager.getCustomFieldObjectByName("YOUR_CF_NAME_HERE");
def myFieldValue = issue.getCustomFieldValue(myField)!=null?issue.getCustomFieldValue(myField).toString():null;
CommentManager commentManager = ComponentAccessor.getCommentManager();
List<Comment> comments = commentManager.getComments(issue);
Hope this helps, Fabio
Like Alex likes this
Christian Schneider
Thank you very much. The thing with the customField did not work out. I changed it from "...byName" to the one, where I have to put in the CustomField-Number. Nevertheless, it did not work either. perhaps, because it's a date? Anyway, I decided to use the "created"-date. Should do for now.
regarding the comments:
 I get the list of the comment-IDs, but not the text itself.
[com.atlassian.jira.issue.comments.CommentImpl@b90a0cf0, com.atlassian.jira.issue.comments.CommentImpl@e94800f7, com.atlassian.jira.issue.comments.CommentImpl@787f731, com.atlassian.jira.issue.comments.CommentImpl@153873f5, com.atlassian.jira.issue.comments.CommentImpl@5108e309, com.atlassian.jira.issue.comments.CommentImpl@9bf5d073, com.atlassian.jira.issue.comments.CommentImpl@b27add91, com.atlassian.jira.issue.comments.CommentImpl@57290461, com.atlassian.jira.issue.comments.CommentImpl@19396fd5, com.atlassian.jira.issue.comments.CommentImpl@86582134, com.atlassian.jira.issue.comments.CommentImpl@76fc0550]
I am struggling the get the comment as a string. Any idea?
here the code with your custom field id and comments management.
Each comment can be retrieved ussing method .getBody
Here new code :
CustomField myField = customFieldManager.getCustomFieldObject(10705L);
for(Comment comment : comments){
YOUR_VARIABLE_HERE = comment.getBody();
Christian Schneider
February 3, 2022 edited
Hi @Fabio Racobaldo _Herzum_
thank you very much. Your example only provides the last comment. I guess, while running through the for-loop, the variable "YOUR_VARIABLE_HERE" is overwritten everytime? So only the last comment is provided to the rest of the script?
I changed the script into this:
def issueStartDate = ( issue.getCreated() != null ? issue.getCreated().format( 'yyyy-MM-dd HH:mm' ) : null )
def issueResolutionDate = ( issue.getResolutionDate() != null ? issue.getResolutionDate().format( 'yyyy-MM-dd HH:mm' ) : null )
def commentManager = ComponentAccessor.commentManager
def comments = commentManager.getComments(issue)
def issueComments = []
comments.each { comment ->
issueComments.add(comment.getCreated().format("dd.MM.yy HH:mm") + ": " + comment.getBody() + System.getProperty("line.separator") + System.getProperty("line.separator"))
log.warn "Issue Key: ${issueKey}"
log.warn "Status: ${issueStatus}"
log.warn "Title: ${issueTitle}"
log.warn "Issue Description: ${issueDescription}"
log.warn "Startdate: ${issueStartDate}"
log.warn "Enddate: ${issueResolutionDate}"
log.warn "Comments: ${issueComments}"
Log:
2022-02-03 14:23:11,693 WARN [runner.ScriptBindingsManager]: Issue Key: ICTPRM-19
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Status: Open
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Title: Test Scriptrunner Listener to Sharepoint
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Issue Description: sdfff
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Startdate: 2022-02-02 12:31
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Enddate: null
2022-02-03 14:23:11,694 WARN [runner.ScriptBindingsManager]: Comments: [02.02.22 16:27: Test
, 02.02.22 16:31: test2
, 02.02.22 16:39: Test3
, 02.02.22 16:42: Test4
, 02.02.22 16:48: Test 5
, 02.02.22 16:55: Test 6
, 02.02.22 16:59: Test 7
, 02.02.22 17:02: Test 8
, 02.02.22 17:04: Test 9
, 02.02.22 17:12: Test 10
, 02.02.22 17:17: Test11
, 03.02.22 13:28: Test 12 Kommentare abrufen
, 03.02.22 13:33: Test 13
, 03.02.22 14:23: Test 14
Now, all the comments are written into a List. I will use this variable to transfer all the text as a string with a RESTClient to a sharepoint list.
Thank you very much for help and effort. You definietely pointed me into the right directions. :-)
You're welcome @Christian Schneider . Please mark my answer as accepted ;)
Christian Schneider
February 3, 2022
Update
I found a nicer way to bring all comments into one variable:
issueComments.add(comment.getCreated().format("dd.MM.yy HH:mm") + ": " + comment.getBody())
def issueCommentsString = issueComments.join('- --- --- --- -')
when transfered via RESTClient/JSON to a sharepoint list, all carriage return/linefeed are lost. This makes short comments almost unreadable.
I did not yet figure out, how to circumvent this. Must be something in the receiving engine of sharepoint, which removes all CRLF from the input...
SERVER
VERSION
8.20.4
Get Certified! ✍️
